ZJ HP30 build ?'s - Page 2 - JeepForum.com
post #16 of 41 Old 02-05-2013, 08:33 PM Thread Starter
riot1987
Originally Posted by riot1987 View Post
Im rebuilding an 88XJ HP30 for my ZJ. Im gonna do a WJ brake and knuckle swap on it as well. Id like to do a high steer too. It'll be on 35's, locked with 4.56's.
Im asking for a parts list what im gonna need, more so what im gonna need for that high steer business.
Thanks
^^This.
Build thread^^
riot1987 is offline
post #17 of 41 Old 02-05-2013, 09:18 PM
steeleman3
Pretty sure the knuckles, drag link, and tie rod all from the wj should work but I'm lookin into the same thing as you so I'm not 100%
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #18 of 41 Old 02-06-2013, 12:42 PM
bananaslug
The WJ axle is wider. Just order from Kolak and Nick will set you up with everything. It should save you some green too since he has the best pricing on JKS. Can get the TREs, rotors, brakes all from him. Just makes it easy.
For hi-steer, I say go with as much JKS stuff as possible...
Get the Goferit TRE flip inserts, JKS steering, WJ TREs (with the RHD TRE for the drag link - knuckle side to clear the sway bar mount), JKS sway bar mounts to clear the hi-steer, and the JKS track bar relocation bracket to bring it in line with the drag link.
bananaslug is offline
post #19 of 41 Old 02-06-2013, 12:55 PM
FAlfani81
I found a '02 wj in aurora im gonna go check it out after work and HOPEFULLY get my brakes off of it...
Your going to want the brakes out of a later year WJ if your going to do the swap. 03 and 04 have bigger calipers and cover more of the caliper and makes the rotors less prone to warping.
FAlfani81 is offline
post #20 of 41 Old 02-06-2013, 01:13 PM
bananaslug
Only caveat is that the larger, later calipers dont fit some 15" wheels.
post #21 of 41 Old 02-06-2013, 05:24 PM
FAlfani81
The larger are called akebono. Not sure the name of the other set
post #22 of 41 Old 02-06-2013, 05:33 PM
bananaslug
Teves.
Kolak sells NEW Mopar Akebonos for like $200 I think if you wanna get fancy.
post #23 of 41 Old 02-06-2013, 05:50 PM
Freestyle713
1994 ZJ
Heres mine. Only thing I've done to it so far are some JKS mini skids. Not sure if I want to do a wj swap, though. But I have plenty of time to decide, this thing isn't gonna be done any time soon. What I probably will do though is order the artec truss, since I have a gift certificate to artec. Not like I can buy anything else from them.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #24 of 41 Old 02-06-2013, 05:59 PM
bananaslug
Could always get these and REALLY do some fancy steering...
http://www.artecindustries.com/Reid-...kle_p_129.html
post #25 of 41 Old 02-06-2013, 06:16 PM
Freestyle713
1994 ZJ
For more than $550 a set, I think I'll pass lol. I aint that hardcore.
post #26 of 41 Old 02-06-2013, 06:25 PM Thread Starter
riot1987
If i was running tons Id get some badass knuckles. I just cant dump that much into a D30. Those are BEEF though
Build thread^^
riot1987 is offline
post #27 of 41 Old 02-06-2013, 06:26 PM Thread Starter
riot1987
If I run WJ knuckles, Do I need WJ ball joints?
Build thread^^
riot1987 is offline
post #28 of 41 Old 02-06-2013, 06:46 PM
bananaslug
IIRC, top one is WJ specific, bottom is the same.
post #29 of 41 Old 02-06-2013, 06:50 PM Thread Starter
riot1987
Nice, good to know
Build thread^^
riot1987 is offline
post #30 of 41 Old 02-09-2013, 07:25 PM Thread Starter
riot1987
Got my JKS spacers from kolak
Build thread^^
riot1987 is offline
