ZJ HP30 build ?'s - JeepForum.com
post #1 of 41 Old 02-01-2013, 07:31 PM Thread Starter
riot1987
ZJ HP30 build ?'s
Im rebuilding an 88XJ HP30 for my ZJ. Im gonna do a WJ brake and knuckle swap on it as well. Id like to do a high steer too. It'll be on 35's, locked with 4.56's.
Im asking for a parts list what im gonna need, more so what im gonna need for that high steer business.
Thanks
Build thread^^
riot1987 is offline
post #2 of 41 Old 02-01-2013, 08:14 PM Thread Starter
riot1987
This is whats on my list so far.
WJ knuckles
2002-2004 WJ brake calipers
JKS spacers
IRO Almost Alloy kit
I was gonna run XJ axle shafts. I heard that 1995+ XJ safts will hold a bigger Ujoint?
I was thinking about getting a WJ drag link and sleeving it but Id like A heavy tierod. I dont wanna spend too much on one is it tough to make one yourself?
Build thread^^
riot1987 is offline
post #3 of 41 Old 02-01-2013, 11:01 PM
steeleman3
I'm planning this exact same swap, except probably a 95+ hp30, swapping out wj knuckle and brakes in the hp then swapping that whole thing in. Seems fairly simple, but I'll keep an eye on this thread. Maybe we could help eachother out Riot.
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #4 of 41 Old 02-02-2013, 04:51 AM
Mark-318-IT
i'd like to do the swap too, i have no infos (so unluckily i can't help) but, as you said, i'll keep an eye here too.
beacuse i'd like to run 33s with lockers
Mark-318-IT is offline
post #5 of 41 Old 02-02-2013, 05:23 AM
nickhay13
I am planning the same swap in the future. Are you guys planning on trussing or otherwise reinforcing the HP30 in anyway?
nickhay13 is offline
post #6 of 41 Old 02-02-2013, 09:28 AM Thread Starter
riot1987
Yeah im gonna build a simple truss for it. Artec recently released on you can buy but Im just gonna make my own im thinking. Im running a Artec truss on my 8.8 and love it!
Build thread^^
riot1987 is offline
post #7 of 41 Old 02-02-2013, 09:30 AM Thread Starter
riot1987
Word. I like the older hp's. The ones with the vac disco have uber heavy upper CA mounts instead of that thin ****. I have to get the proper seals though for the disco bypass
Build thread^^
riot1987 is offline
post #8 of 41 Old 02-02-2013, 09:39 AM Thread Starter
riot1987
Im more worried about the innerds not so much the tubes bending as Im not THAT hard on it. But definetly going to reinforce my C's at least. I want to keep my weak point away from my differential. Im hoping to break a Ujoint or axle shaft before I **** up my R&P.
Build thread^^
riot1987 is offline
post #9 of 41 Old 02-02-2013, 09:44 AM Thread Starter
riot1987
I found a '02 wj in aurora im gonna go check it out after work and HOPEFULLY get my brakes off of it...
Build thread^^
riot1987 is offline
post #10 of 41 Old 02-02-2013, 10:19 AM
nickhay13
I hear ya. I plan on running the same setup with 4.56 and 35"s when that time comes. I'm pretty easy on the skinny though so I'm not too worried about it.
post #11 of 41 Old 02-02-2013, 10:40 AM
steeleman3
Oh gotcha, that sounds like a good option if you can seal it properly, I might try that direction. Where you getting the seals?
post #12 of 41 Old 02-03-2013, 12:17 AM Thread Starter
riot1987
Got a pass side '02 WJ caliper at the yard today
Build thread^^
riot1987 is offline
post #13 of 41 Old 02-03-2013, 12:17 AM Thread Starter
riot1987
Im gonna try to get them at the parts store up the street. If not, order them
Build thread^^
riot1987 is offline
post #14 of 41 Old 02-03-2013, 12:24 AM
WhiteOut
WhiteOut's Avatar
Strip it to the tubes and rebuild it with new, you'll be cutting a lot off to put the truss on anyways. New brake stuff is cheap and no point in running used, anything gear related should be new, aftermarket mounts are cheap and beefier than stock. Used shaft are fine once you put all new joints in them.
WhiteOut is offline
post #15 of 41 Old 02-03-2013, 12:47 AM
jtackerman28
For brakes it depends on the core if I were you I'd buy jy calipers to get the core back and have new calipers because they are only like 30 at autozone ect. For brand new but the core charge is quite expensive
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
