Zj horn finally died.....good replacement?
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
First question, does the ZJ use a dual horn set up? My horn sounded flat for the year it worked. It just died last week and I need to replace it.
I was thinking of using this Hella 85104 kit. ![]() Is it a simple install? Where is the horn relay located so I can put in the new one when I get it, if this kit is a good choice? Thanks!
#2 |
Belief In All Things Jeep
Its a two horn setup - hi and lo tone. I recently replaced mine with some Fiamm replacements from Carquest. My low tone horn was shorting and blowing the horn fuse. I think the Hella kit is probably better and a fine choice. You shouldn't need to replace the horn relay which is located in the underhood fusebox (PDC) because its good to 30 amps. Install is easy. Unless you get OEM horns, you'll need to do a little electrical connector work. I cut the OEM connectors off and soldered up my own.
#3 |
Sweet! I'm ordering those right now then.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
