ZJ hits bump then gets shimmy - JeepForum.com
post #1 of 7 Old 03-12-2002, 12:32 AM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Commin over from the Cherokee Forum... my Dad's got a 96 ZJ and says when he's going about 50 - 55 mph, and hits a bump, he then feels a shimmy or vibration in the steering wheel. Any thoughts on what could cause this? He says it only started doing this in the past few weeks. FYI, he has no lift, tires are 3 years old and its been quite some time since he's had an alignment.
Thanks,
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #2 of 7 Old 03-12-2002, 08:14 AM
fitzer
Thanks,
EricsXJ,
Balance and rotate tires then alignment.
If he still gets the vibration after that, post again and I can give some resources for what to check/do next.
Peace...
93 ZJ 4.0, Rancho 9000's, Rancho Stabilizer, Splitfire plugs, BFG A/T 235/75/15's
More to come...
fitzer is offline
post #3 of 7 Old 03-12-2002, 08:43 AM
motox77x
ericsxj
have you looked at the front track bar. this is a very common failure and could cause the axel to float around a little after a freeway speed bump...???
96 Grand Cherokee/ 4.0L/ RE 4.5" lift/ SYE/ Woods drivelines/ 31's/ many other homemade goodies
motox77x is offline
post #4 of 7 Old 03-12-2002, 12:50 PM
g95jgc
Back in the day when my ZJ was stock, I had the same problem. Really irritating. I replaced the steering damper and never had another problem with it.
John
g95jgc is offline
post #5 of 7 Old 03-12-2002, 05:24 PM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Thanks for the ideas so far guys!
Mottox77x, ya I "looked" at the track bar. In fact thats the first thing I did when he told me of the problem LOL! But.. his track bar is the same as my old stock track bar. Question is, how do the fail? At the ball joint?
Hadn't thought about the steering damper. Hmm... Thanks
Eric
My website -
EricsXJ is offline
post #6 of 7 Old 03-15-2002, 06:54 AM
fitzer
Track bars usually fail at the joint - unless you really deform one offroad.
Lateral (horizontal) movement of the trackbar is a no-no.
If the steering stabilizer is truly shot then that could be the culprit. Is there any visible oil leakage? If not, the best way I have heard to test the stabilizer is to remove one end - the easier of the two (can't recall which at the moment)and manually acuate the stabilizer. If you feel any spots in which there is little or no resistance - a dead area - it's bad.
However, if the stabilizer is not bad and you replace it you are just masking a problem that will eventually occur again even with a newer stabilizer.
fitzer
More to come...
fitzer is offline
post #7 of 7 Old 03-15-2002, 05:17 PM
GrandCherokeeLifer
John and Fitzer are right. I had the same problem and the dealer replaced my steering stablizer/dampener and it fixed the problem.
Alex
96 Grand Cherokee Limited
5.2 V8 no mods.
04 VW Touareg
GrandCherokeeLifer is offline
Meteor hits windshield and ice build up BlueSteelJP WK Grand Cherokee & XK Commander Forum 1 02-03-2010 12:56 PM
Picture request sicne there were no hits in the proper thread MeWJWifeZJ ZJ Grand Cherokee Forum 3 02-17-2009 01:10 PM
tie rod hits disconnect bracket? 1sportsdoc ZJ Grand Cherokee Forum 11 06-10-2008 02:15 PM
Bump Steer (shimmy) on a WJ PSYCH0 ZJ Grand Cherokee Forum 12 08-31-2007 05:31 PM
Bump Go !!!, (Opposite of stop bump) madmarchhare ZJ Grand Cherokee Forum 7 08-25-2006 06:04 PM
