ZJ help - JeepForum.com
post #1 of 9 Old 12-23-2011, 08:55 AM Thread Starter
Dluenz
ZJ help
I have a 1993 ZJ with the five speed manual and the I6, runs and drives great but there is a weird rubbing noise when I'm coasting. If I really step on it there is no noise but otherwise there is and it seems to go faster the faster I go. I had it on a lift and everything seems to have checked out so im really lost as to what it could be. Also I'm looking for some cheap but cool mods I can do! Thanks!
Dluenz is offline
post #2 of 9 Old 12-23-2011, 09:02 AM
ZJPunk98
Does the noise appear when you turn or just coast? is it tire/road noise? if its a whining noise under power, that would be your pinion bearings.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #3 of 9 Old 12-23-2011, 09:05 AM
PolkaPower
It could be any number of things. Pinion bearings, wheel bearings, worn brake rotors........ What area is the noise coming from?
PolkaPower is offline
post #4 of 9 Old 12-25-2011, 01:28 PM Thread Starter
Dluenz
it seems to be coming from the rear, and if im under power its gone, mostly when im coasting.
Dluenz is offline
post #5 of 9 Old 12-25-2011, 01:36 PM
TallyZJ
Check to see if anything is touching the drive shaft in any way. When under power the pinion will rotate. When you coast it returns to its normal orientation and something may be rubbing it.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #6 of 9 Old 12-25-2011, 04:36 PM
Degra101
Lucky !
Degra101 is offline
post #7 of 9 Old 12-26-2011, 12:59 AM
KoreaZJ
1994 ZJ
Scarey!
________________
KoreaZJ is offline
post #8 of 9 Old 01-06-2012, 09:15 AM Thread Starter
Dluenz
alright thanks, I'll check that out.
Dluenz is offline
post #9 of 9 Old 01-09-2012, 08:57 AM Thread Starter
Dluenz
Figured it out, bearing was going. Thanks for your help everyone!
Dluenz is offline
build , noise , rear end , zj
