-   -   ZJ help (http://www.jeepforum.com/forum/f13/zj-help-1304933/)
Dluenz 12-23-2011 08:55 AM
ZJ help
I have a 1993 ZJ with the five speed manual and the I6, runs and drives great but there is a weird rubbing noise when I'm coasting. If I really step on it there is no noise but otherwise there is and it seems to go faster the faster I go. I had it on a lift and everything seems to have checked out so im really lost as to what it could be. Also I'm looking for some cheap but cool mods I can do! Thanks!
ZJPunk98 12-23-2011 09:02 AM
Does the noise appear when you turn or just coast? is it tire/road noise? if its a whining noise under power, that would be your pinion bearings.
PolkaPower 12-23-2011 09:05 AM
It could be any number of things. Pinion bearings, wheel bearings, worn brake rotors........ What area is the noise coming from?
Dluenz 12-25-2011 01:28 PM
it seems to be coming from the rear, and if im under power its gone, mostly when im coasting.
TallyZJ 12-25-2011 01:36 PM
Check to see if anything is touching the drive shaft in any way. When under power the pinion will rotate. When you coast it returns to its normal orientation and something may be rubbing it.
Degra101 12-25-2011 04:36 PM
Lucky ! :drool:
KoreaZJ 12-26-2011 12:59 AM
Scarey!
________:peaking:________
http://img809.imageshack.us/img809/7871/polka.jpg
Dluenz 01-06-2012 09:15 AM
alright thanks, I'll check that out.
Dluenz 01-09-2012 08:57 AM
Figured it out, bearing was going. Thanks for your help everyone!
The time now is 09:22 AM.
