ZJ Heated Memory Seat install into Laredo (writeup) - Page 2 - JeepForum.com
post #16 of 31 Old 07-06-2013, 05:57 PM
dunkeye11
Originally Posted by 93zjgrand
well i do have the larado model and it dows not have power seats, but i do have a wire under both seats coming out wear the rear florr vents are. do you think that would be plug and play
No that wire is ment for the seat belt light on the drivers side
Unless it is a multi port plug
My question is what is the ignition wires on the ZJ what color are they!!!!!
dunkeye11 is offline
post #17 of 31 Old 07-23-2013, 11:11 AM
93zjgrand
Ido wat color, but wire is on both sides for each seat
93zjgrand is offline
post #18 of 31 Old 12-01-2013, 01:49 PM
Flat_Black_ZJ
I have a 98 Laredo and it had factory power leather and I have found a set of leather heated seats what all do I need to take out of donor other that seats and switch that's in door panel?
Flat_Black_ZJ is offline
post #19 of 31 Old 01-07-2014, 10:13 AM
davidtownsend
2006 WK
Could you put a heated unit into a cloth seat? Or is it pointless?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #20 of 31 Old 03-21-2014, 06:48 AM
RetiredGuns
1994 ZJ
So I have Power Seats in a donor vehicle, a 1995 ZJ, and I want to put them in a Non-Powered 1994 ZJ. There is a plug with 2 wires under each seat in the 94. They are both cloth seats and no heated or memory is involved, is this a plug and play?
RetiredGuns is offline
post #21 of 31 Old 03-21-2014, 11:51 AM
xcaliber81
could be if its directly under the seat and not off to one side. may need to put a fuse in.
xcaliber81 is online now
post #22 of 31 Old 03-23-2014, 06:50 PM
RetiredGuns
1994 ZJ
post #23 of 31 Old 03-23-2014, 06:54 PM
xcaliber81
Got it workin?
post #24 of 31 Old 07-14-2015, 06:43 PM
Bodybuilder21
I'm trying to wire in a passenger power leather seat into my 96...the seat has a red (power) and black (ground)..obviously I can splice into the current ground wire under the seat but is there a "hot" 12v wire in my stock wiring harness I could splice into or do I need to run a wire all the way to the fuse box??
98' 5.9- racejeep build (boosted 408 dreamin')
96' 4.0- 5.5"- currently torn down for 4.7 stroker
Bodybuilder21 is offline
post #25 of 31 Old 07-15-2015, 04:01 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
You can pull a plug out of a junker,release the pin for supply, install it in your connector, and solder, insulate ect. You will have a better situation than a hack and tap to another circuit.
Originally Posted by HighLonesome
coralman is offline
post #26 of 31 Old 07-15-2015, 10:46 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, I would get as much of the power harness from the donor as I could. It can't go that far, the fuse panel is right there.
kg6mov is offline
post #27 of 31 Old 02-27-2016, 03:08 PM
sgt37
Do the heating elements bun out? 97 limited with factory heated memory seats. I have power to the blue with black tracer wire to the connector under the seat when the switch is on but no heat in either seat
sgt37 is offline
post #28 of 31 Old 02-27-2016, 03:19 PM
kg6mov
Hears the voices
kg6mov's Avatar
They can burn out, but that's not usually the failure. It's often a broken wire inside the seat.
kg6mov is offline
post #29 of 31 Old 03-01-2016, 06:41 AM
akk32
Would the memory function work on the upgraded cloth Laredo seats?
1997 Jeep Grand Cherokee Laredo 4.0 Selec-Trac 4WD Chargold II 230,000 Miles
1996 Jeep Grand Cherokee Laredo 4.0 Selec-Trac 4WD Chargold II 208,000 Miles (Totaled, working on rebuilding it)
akk32 is offline
post #30 of 31 Old 03-01-2016, 08:01 AM
coralman
coralman's Avatar
If you have the memory module under the drivers seat, the1-2 button in the door panel,and all related wiring installed yes it would. You might have to tap onto the ccd bus but I can't remember on that one. If going that far I would install the memory mirrors as well.
coralman is offline
97 Laredo GC Heated front seat wiring lorrick ZJ Grand Cherokee Forum 0 05-30-2009 12:25 PM
HELP with wj heated seat install dmolaver15 ZJ Grand Cherokee Forum 4 01-26-2009 06:59 PM
Heated seat in ZJ Laredo parnell5150 ZJ Grand Cherokee Forum 1 09-09-2007 12:20 AM
Memory Heated Seat Module broken WolfgangK ZJ Grand Cherokee Forum 1 09-13-2006 01:48 PM
Aftermarket Heated Seat Install scottjclaypool ZJ Grand Cherokee Forum 23 10-28-2005 04:11 PM
