ZJ Headlight aiming - JeepForum.com
post #1 of 18 Old 01-19-2010, 08:56 AM Thread Starter
ajbadger3
1994 ZJ
ZJ Headlight aiming
I know this has been discussed numerous times already, but I've searched and searched the forum for an answer with no luck. Can someone show me (ideally with a photo or two) where the headlight adjustment screws are on a ZJ? Thanks.
ajbadger3 is offline
post #2 of 18 Old 01-19-2010, 12:59 PM
revlis240
1994 ZJ
open the hood, look at the back and side the headlight housing. There are 2 things to turn, one for vertical and one for horizontal. Both use a 6mm allen head. Its the only thing there that uses an allen.
HTH
Abe
1994 ZJ 4.0 4x4 almost stock | 1994 ZJ 5.2 4x4 totally stock
revlis240 is offline
post #3 of 18 Old 01-19-2010, 02:10 PM
torchd
2003 WJ
that reminds me, I need to adjust mine..
Like he said above they are right there on top of the headlights. The top of the screw looks like a star..
torchd is offline
post #4 of 18 Old 01-19-2010, 02:24 PM Thread Starter
ajbadger3
1994 ZJ
Thanks guys! I appreciate the help.
post #5 of 18 Old 01-19-2010, 02:36 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Spray WD40 in the adjuster holes and work the adjuster back and forth to loosen it up. The plastic gears can strip out easy.
HighLonesome is offline
post #6 of 18 Old 01-19-2010, 03:16 PM
torchd
2003 WJ
how high should the beam pattern be? I am not sure if my lights are to low or to high....
torchd is offline
post #7 of 18 Old 01-19-2010, 03:41 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
HTH
Abe
they're torx, not allen. t-30 iirc.
ratmonkey is offline
post #8 of 18 Old 01-19-2010, 03:46 PM
LordHobbit
Allen on my '93
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #9 of 18 Old 01-20-2010, 07:35 AM Thread Starter
ajbadger3
1994 ZJ
Originally Posted by LordHobbit View Post
Allen on my '93
6mm allen on my '94 as well.
post #10 of 18 Old 01-20-2010, 11:04 AM
JesseOR
Even Haynes says allen for ALL ZJ's.
Outer screw-verticle
Inner screw-horizontal
They are set below the sheet metal over the headlights. Look down and you'll see them.
I think the proper aiming is at 25ft the beam should be at the horizontal center line(floor to center of headlight) and verticle center line(center of jeep to center of headlight) of each head light.
This should be done on a flat/level surface and a wall and Haynes says a 1/2 full gas tank(that I don't think matters too much).
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #11 of 18 Old 01-20-2010, 05:45 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
haynes sucks. to put it simply. great for changing your oil, sometimes.
will a hex bit fit into a torx head? yes. is it right? no.
post #12 of 18 Old 01-20-2010, 06:05 PM
JesseOR
Can you fit a torx in a hex? Yes.
You can look and see whether they are hex or torx. Its a big difference. Mine are definitely hex.
And I love haynes. Its great for the "back yard" mechanic. Granted they don't go as deep as some but they work.
To each his own. They don't work for you.
And by the way, haynes has correct info.
-Jesse-
GO DUCKS!
JesseOR is offline
post #13 of 18 Old 01-20-2010, 06:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
haynes is what?
post #14 of 18 Old 01-20-2010, 06:46 PM
JesseOR
Hmmmm...
That looks nothing like ours. Yours is a different body style. That doesn't even look factory. Is that looking down from above?
Ours have a large plastic disc ontop that is clearly a hex.
-Jesse-
GO DUCKS!
JesseOR is offline
post #15 of 18 Old 01-20-2010, 06:49 PM
JesseOR
I don't know if you realized that mr '97.
His is a '94, which is same body style as my '93
-Jesse-
GO DUCKS!
JesseOR is offline
Headlight Aiming njl2 WK Grand Cherokee & XK Commander Forum 4 08-10-2013 08:37 PM
aiming my aux. lighting BransJeep ZJ Grand Cherokee Forum 4 04-14-2009 03:55 AM
WJ Headlight Aiming, HOW? Rito ZJ Grand Cherokee Forum 3 03-22-2009 01:43 PM
wk headlight aiming datterbe3780 ZJ Grand Cherokee Forum 3 03-22-2009 01:34 PM
help - WJ headlight aiming Tdad ZJ Grand Cherokee Forum 4 09-03-2006 08:19 AM
