ZJ Head Liner - Page 2 - JeepForum.com
post #16 of 18 Old 08-24-2011, 06:32 AM
KillaJeep4569
2006 WK
Originally Posted by TheDozarian View Post
Everything was on the cheap at Walmart, Killa. The most expensive thing I bought was a new Torx set that had the T-50 bit for the shoulder belt bolts. Here's what I bought:
3M Headline Spray Adhesive x2 - $20
5'x8' Dark Grey Fleece Fabric - $12
Torx Bit Set - $23
Granted, I had a basic Torx set and and all the other tools I needed. Which, by the way, was just a phillips-head screwdriver, flat-tip screwdriver, the torx driver (I can't recall what size), and maybe a pair of pliers.
So all in all, I have $55 dollars in it. And my time. I'd recommend havin' a second set of hands, if you can, as it'll help holding it up while you're re-installing it.
how do you wrap her? or did you just spray and push her against the body?
KillaJeep4569 is offline
post #17 of 18 Old 08-24-2011, 11:49 AM Thread Starter
TheDozarian
1994 ZJ
After I took out the liner and cleaned it, I sprayer it down twice with adhesive and then carefully sat the blanket down on it. I quickly hand-pressed it down onto the liner and worked out the bubbles.
After that I cut out the console and screw holes. I mad sure to drape enough over all the edges so that it could be tucked up and under upon installation. Hope that helps!
I have nothing to say at this time. That is all.
TheDozarian is offline
post #18 of 18 Old 08-24-2011, 12:22 PM
tato1111
My buddie did this in his cummins. He used a camo fabric and spray adhesive. IMO it looks better than the stock liner. I might have him do it im my jeep but the liner is fine and its hard ruining it.
White zj 6in. 33x12.5 1995
<--Mods in profile
tato1111 is offline
Bed Liner. ECMUDSLINGER ZJ Grand Cherokee Forum 2 09-20-2010 04:09 PM
Whats above the head liner? silver_laredoSE ZJ Grand Cherokee Forum 7 01-02-2010 06:07 PM
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 10:49 AM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 08:35 AM
Going head to head with these specs which jeep will perform better offroad, keeth1123 ZJ Grand Cherokee Forum 6 03-02-2007 08:23 PM
