ZJ hatch replacement where to unplug? - JeepForum.com
post #1 of 3 Old 07-19-2009, 09:33 PM Thread Starter
spidermonkey
A friend of mine bought my brothers ZJ. He is replacing the hatch and was wondering where to dig to unplug the harness. I didn't have a clue.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 3.5" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here:
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers
spidermonkey is offline
post #2 of 3 Old 07-19-2009, 09:53 PM
j.love
j.love's Avatar
1994 ZJ
lift the gate open,
remove the interior panel,
look for hidden screws under the carpet at either side near the bottom,
at the top of the hatch on either side of the third brake light remove the two black plastic wire connector retainers.
Behind those retainers will be 3 connectors on each side. disconnect them and feed them threw the top of the of the hatch.
pull the panel with the cargo light on it.
pull down the headliner a bit and disconnect the washer hose line.
remove the two pistons, clips on the bottom of the piston will pry out and then pull to get them free.
close the hatch!
jump inside and unbolt the 3 bolts for the hinges.
jump outside.
lift the whole hatch from the handle and then place hatch on ground.
have a beer and admire your work.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #3 of 3 Old 07-20-2009, 07:41 AM Thread Starter
spidermonkey
Thanks for the quick response.
So, if I unplug the IAC... ghiotom ZJ Grand Cherokee Forum 20 05-21-2015 02:53 AM
How do I unplug my power antenna? 02Lightning ZJ Grand Cherokee Forum 7 11-04-2011 09:38 PM
Rear Hatch Replacement cost??? SouthernboyWJ ZJ Grand Cherokee Forum 3 04-25-2007 09:55 PM
How to unplug electic fan? pjbassfuzz ZJ Grand Cherokee Forum 1 11-13-2005 07:40 PM
Replacement Rear Hatch Lock stussysteve ZJ Grand Cherokee Forum 1 06-29-2004 07:30 AM
