ZJ has died.... - JeepForum.com
post #1 of 7 Old 06-09-2013, 10:48 AM Thread Starter
Mike-W
ZJ has died....
- Sorry, I have read a number of threads but just need some pointers on where to start...
- I have a 96 turned over this morning then died, now won't turnover, have charged battery all electrics are working but it just won't turn over..
- Where should I start?
Mike-W is offline
post #2 of 7 Old 06-09-2013, 10:54 AM
JasonStebbins
It's not cranking over at all? Or did it start and then die?
That's usually a dead battery/alternator/starter.
Does it make a clicking sound or one click or anything when you try to start it?
Use a long screwdriver and jump the starter with the terminals and see if that works.
Poop
JasonStebbins is offline
post #3 of 7 Old 06-09-2013, 10:56 AM Thread Starter
Mike-W
If I leave the hood up I can hear a faint double click
Mike-W is offline
post #4 of 7 Old 06-09-2013, 11:01 AM
JasonStebbins
If all your electronics are working I would try jumping the starter. Turn the key to the ON position and use a screwdriver to make a bridge for the terminals.
It could also be the alternator not charging the battery, but you won't know until you get the charging system tested at a parts store or with a voltmeter.
Poop
post #5 of 7 Old 06-09-2013, 03:25 PM Thread Starter
Mike-W
Had a look underneath haven't jumped it yet but looks lie the oil filters leaking on it...
Mike-W is offline
post #6 of 7 Old 06-09-2013, 04:51 PM
JasonStebbins
That's the oil filter adapter leaking on it. There are three O-rings behind the adapter that go bad over time.
Have someone jump you and see if it starts, that will narrow it down to a battery/alternator issue.
Poop
post #7 of 7 Old 07-14-2013, 01:34 AM Thread Starter
Mike-W
Replaced the starter motor and issues has been resolved, also appears my battery drain has vanished as well so bonus
Mike-W is offline
