-   -   ZJ has died.... (http://www.jeepforum.com/forum/f13/zj-has-died-1534165/)
Mike-W 06-09-2013 09:48 AM
ZJ has died....
- Sorry, I have read a number of threads but just need some pointers on where to start...
- I have a 96 turned over this morning then died, now won't turnover, have charged battery all electrics are working but it just won't turn over..
- Where should I start?
JasonStebbins 06-09-2013 09:54 AM
It's not cranking over at all? Or did it start and then die?
That's usually a dead battery/alternator/starter.
Does it make a clicking sound or one click or anything when you try to start it?
Use a long screwdriver and jump the starter with the terminals and see if that works.
Mike-W 06-09-2013 09:56 AM
If I leave the hood up I can hear a faint double click
JasonStebbins 06-09-2013 10:01 AM
If all your electronics are working I would try jumping the starter. Turn the key to the ON position and use a screwdriver to make a bridge for the terminals.
It could also be the alternator not charging the battery, but you won't know until you get the charging system tested at a parts store or with a voltmeter.
Mike-W 06-09-2013 02:25 PM
Had a look underneath haven't jumped it yet but looks lie the oil filters leaking on it...
JasonStebbins 06-09-2013 03:51 PM
That's the oil filter adapter leaking on it. There are three O-rings behind the adapter that go bad over time.
Have someone jump you and see if it starts, that will narrow it down to a battery/alternator issue.
Mike-W 07-14-2013 12:34 AM
Replaced the starter motor and issues has been resolved, also appears my battery drain has vanished as well so bonus
The time now is 09:14 PM.
