ZJ Fuel Filter Replacing - JeepForum.com
post #1 of 4 Old 03-03-2010, 12:47 AM Thread Starter
davooo
Thankfully the 96 ZJ came with inline filter so changing it over is not a headache. Having never performed this before the only guide I could find online was this link.
How to replace fuel filter for 1996 Jeep Grand Cherokee L6 4.0. - JeepsUnlimited.com Forums
My only concern is purging the fuel lines, is pulling the relay sufficient, am I going to have problems when new filter is back on or is it simply as this guide describes..thank you in advance.
davooo is offline
post #2 of 4 Old 03-03-2010, 01:19 AM
bigbill888
I have never purged anything. You will spill a little gas when you do this so don't smoke or have some ignition source nearby. Dont let the crap get in your eyes. It may take just a little extra cranking when you first start up as it digests that air bubble.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 4 Old 03-03-2010, 06:31 AM
melk
I have a 96 too. Prior to owning this Jeep (got it about 6 months ago) the only thing I had ever done was change a tire and jump a battery.
New fuel filter was my first project and it really is easy... Since then I've changed the oil, did the brakes, new plugs etc.
After you pull the relay you can try starting the Jeep a few times to purge any remaining fuel in the front line. Either way some gas will spill, just be ready for it.
melk is offline
post #4 of 4 Old 03-03-2010, 02:36 PM Thread Starter
davooo
thanks for reply melk, as for texaszj1 removing a 'drug' comment - go and get a life loser
davooo is offline
99 wj fuel filter Howiedooit ZJ Grand Cherokee Forum 5 01-17-2010 04:41 PM
Wont start after replacing my fuel filter coolio365 ZJ Grand Cherokee Forum 9 03-15-2009 09:14 PM
Wont start after replacing my fuel filter coolio365 ZJ Grand Cherokee Forum 2 03-15-2009 02:12 PM
Fuel filter help for a 94 ZJ deeznutz206 ZJ Grand Cherokee Forum 4 11-22-2007 03:36 PM
Replacing fuel filter need help E430 ZJ Grand Cherokee Forum 12 09-29-2005 09:51 AM
