ZJ Front to rear lift How much lift should i expect? - Page 2 - JeepForum.com
post #16 of 31 Old 07-15-2010, 01:35 PM
StellaTheZJ
Front track bar needs nothing for 3", but the back did need to be lengthened. I heated and pressed the stock one a little longer to center the rear axle when it's sitting empty.
To deal with this, there are actually at least three ways. First, straighten what you've got a wee bit, like I did. Or, you can go for an adjustable track bar instead, which is nice because it may accommodate larger lifts in the future. Or go for the relocation bracket, which people say can rip off, but may reduce the chances of your tires rubbing on the springs during compression, when the axle moves over. The relocation bracket maintains stock geometry for the rear track bar, so the axle has less lateral movement with a relocation bracket than with a lengthened or adjustable track bar.
StellaTheZJ is offline
post #17 of 31 Old 07-15-2010, 02:21 PM
melk
OK, so I've got a stock 4.0
I would move the front coils to the back... and what do I put in the front?
melk is offline
post #18 of 31 Old 07-15-2010, 03:17 PM
StellaTheZJ
You put 3" spacers in the front, with your stock coils. SO, 4 stock front coils, 2 spacers, and you're lifted. Then, you'll be looking for shocks (although stock are fine if you're not wheeling), longer rear track bar solution, and probably rear LCAs to deal with any driveline vibes you don't like.
post #19 of 31 Old 07-15-2010, 04:51 PM
melk
Well I need to replace my shocks anyway so it would be a good time to do it.
I haven't seen 3" spacers though, I thought 2" maybe 2.5" is the max safest size?
melk is offline
post #20 of 31 Old 07-15-2010, 10:00 PM
StellaTheZJ
3" is definitely safe for the front, and Fat Bob's is at least one place you can buy them.
With liability the way it is, you know this is safe if people are actually selling it!
post #21 of 31 Old 07-16-2010, 06:17 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Jeep ZJ Grand Cherokee Suspension Lift If you are going to buy spacers, used coils for the front, a trac-bar bracket, shocks, and lower control arms, this will likely be cheaper than sourcing the parts individually.
xjfever is offline
post #22 of 31 Old 07-17-2010, 12:58 AM
StellaTheZJ
Spacers are $50 (plus shipping)
Adjustable Control Arms are $150 shipped
The trackbar can be straightened for free, and I didn't actually need swaybar endlinks for the first 12 years I had this lift in (then I made discos), but it's easier to bolt on the bracket than to straighten.
The shocks from that kit are $30 each plus shipping, so, say $150
Coils cost whatever your local yard charges ($20 a pair plus taxes near me).
In other words, you certainly don't save much, if anything, by piecing it together!! Good find XJfever.
post #23 of 31 Old 07-17-2010, 08:02 PM
x91j
1997 XJ Cherokee
ive been reading for weeks. everyone says that the front and rear track bar arnt necessary but a good thing to get once u get the money.
x91j is offline
post #24 of 31 Old 09-07-2010, 08:31 PM
ISUzj
2005 WK
yes and on the rear the sooner the better for either a bracket or a trackbar, because after time, your springs will contact your swaybar extensions and make quite the amount of noise and you will be posting things on JF like " ahhh the noise is driving me nuts!!" or my tire sounds like its going to fall off!!!
I went a year and a half on a stock TB with a 3" lift... i would not advise it.
I am in the process of going through my entire suspension before winter to get it it tip-top shape (for a 15 yr old vehicle)
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
ISUzj is offline
post #25 of 31 Old 02-20-2013, 07:41 AM
jwe
Im about to start on my front to rear lift on my 94.I have the 4.0 and bought some rubicon express 3.5 for the front.I just need to get the dang rear tires off which wont move
jwe is offline
post #26 of 31 Old 02-20-2013, 08:40 AM
PolkaPower
For front to rear swap just subtract the amount you would pay for two springs you would have bought for the back and that's your price. That is the only savings.
PolkaPower is online now
post #27 of 31 Old 02-20-2013, 02:19 PM
offroadjeep4x4
Sorry to jumo in but how would one spot an Upcountry equipped ZJ at the yard? Do they have badging on them stating such?
offroadjeep4x4 is offline
post #28 of 31 Old 02-20-2013, 02:24 PM
PolkaPower
Different color shocks. Full skid plates and hooks. 1" taller.
post #29 of 31 Old 02-20-2013, 02:58 PM
JohnnyZJ
I6 ZJ coils rear. give ou 3" been there.
if you have an I6 ZJ you could get up country springs (V8) and run them up front with a 2.5" spacer to get 3" give or take. done this. it rode nice.
you will need new shocks.
rear track bar was ok. i'd definitely do a front adjustable track bar now though. now; you can just reuse your stock one, and redrill the hold over a little but, but eventually, you are going to kill the joint on this track bar as the jeeps old etc. blah blah blah. so might as well do it now.
also, same with control arms. if hte bushings aren't shot they will be eventually. as Polka said, theres more to it than just springs.
THAT SAID............... for just the basic 3" I6 coils,ZJ, eithe rfront 3" springs or the stupid 3" spacer, a front track bar and shocks. fairly cheap still. in fact, i think IRO sells a front to rear kit like that
quite frankly, if you're just running a 31" tire and cost is important i'd just get a 2" budget boost and call it good.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #30 of 31 Old 02-20-2013, 03:19 PM
PolkaPower
Front 3" wider than rear ( temporarily )... What to expect? CLNinja ZJ Grand Cherokee Forum 13 09-29-2009 01:55 PM
front to rear lift 97 zj krasian ZJ Grand Cherokee Forum 1 08-20-2008 04:26 PM
front to rear lift shano2007 ZJ Grand Cherokee Forum 1 12-17-2007 12:26 PM
Installing 4.5" lift. What to expect on the install. bjl95mustang ZJ Grand Cherokee Forum 12 05-07-2007 08:17 AM
zj front to rear spring 4" lift rear track bar info autobeamhotmail ZJ Grand Cherokee Forum 3 03-01-2007 03:07 PM
