ZJ Front Bumper Trim - JeepForum.com
post #1 of 3 Old 05-24-2011, 04:20 PM Thread Starter
biebs53
What's the best tool to use for this? Will it chip the paint or is it best to heat it up and then trim? Anyone have any pics? I barely hit the bottom of the bumper when i turn. The fenders are going to stay stock for now but need to trim the front bumper a little. Do i need to cut the insert in the wheel well?
1998 Jeep Grand Cherokee 5.9 Limited
Build thread:
biebs53 is offline
post #2 of 3 Old 05-25-2011, 07:55 PM
khakioutlaw
I have the "unpainted" gray bumper and I used a heat gun and a utility knife (razor) to trim mine about 3/4 on an inch on the lower half. I drilled out the lower plastic rivets on the inner fender skirt before I trimmed the bumper. Once I trimmed the bumper, I took a zip tie and ran it through the lower part of the inner fender to the lower bracket on the bumper support to keep it from hitting the tire. Originally I got some aftermarket push rivets from the local auto store but they never really "held" the inner fender skirt to the bumper like the original ones did. Hence why I used the zip tie to keep it from moving around. It looks original and you can't even tell it's there. I'll try and get some pics up by tomorrow to show you. Hope this helps!
khakioutlaw is offline
post #3 of 3 Old 05-25-2011, 07:57 PM Thread Starter
biebs53
Thanks. I ended up doing mine with a hand saw. I have one side done and ill do the other side shortly. I cut out a good chunk and folded ot down and epoxy'd it and it looks good so far. I'll probably use zip ties too
Build thread:
biebs53 is offline
zj front bumper trim xj51 ZJ Grand Cherokee Forum 8 03-20-2014 04:54 AM
Front Bumper Trim _98_ZJ_ ZJ Grand Cherokee Forum 3 02-01-2009 01:15 PM
removing front bumper and trim questions jdubbs107 ZJ Grand Cherokee Forum 16 03-31-2008 11:38 AM
WJ Front Bumper Trim? BzJeep ZJ Grand Cherokee Forum 11 02-06-2008 04:42 PM
Front Bumper Trim? RoadRunner ZJ Grand Cherokee Forum 0 04-29-2002 09:09 AM
