Quantcast ZJ front bumper mounting points? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ZJ front bumper mounting points?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 11-11-2007, 02:28 PM   #1
tirus89
Well, I tore my front stock bumper off and well, I dont know where to mount this bumper im planning on fabbing? Does anyone have any pictures or any information to help me out? Thanks!
Im a student and unemployed and have a Haynes.
//93 ZJ//5.2L//NP249//K&N Fipk Gen II//2" BB w/BD AT Shocks//4.10's//31" Cooper Discovery STT's//Cstm Frnt Bmpr//Custom Rear Tube Bmpr//3" Magnaflow exhaust w/high flow cat//500RMS Pioneer Amp//600RMS 12" JL Audio Sub//4 Hella 500's on Cstm Light Bar//Sealed Intake Box w/ ram air//
tirus89 is offline   Reply With Quote
Old 11-11-2007, 03:09 PM   #2
tirus89
anybody? anything?
Old 11-11-2007, 03:37 PM   #3
Darthteddy
1955 M-38
If your looking at the front of your jeep, you will see 2 rectangular holes in the sheet metal that have rounded corners. They lead to the "frame rails". On said "Frame rails", there will be holes for a factory tow hook package. Your gonna have to fab up a plate that slides in there, and run bolts through the "frame rail", as if the bumper were the tow hooks. Then attach your bumper to the other end of the plate and your all done.
And geez...have some patience. .. . It had only been 30 minutes after you posted that you posted again.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline   Reply With Quote
Old 11-11-2007, 04:39 PM   #4
Trouble Maker
Trouble Maker's Avatar
Most people also take a Dremel or grinder with a zip-cut wheel and trim the sheet metal out so there is a straight surface to work with. You end up with a rectangular hole about 2" x 4" if you trim it out. When I did mine I used the factory tow hook brackets to sandwich a 4" by 1/4" flat bar in between the bracket and unibody and built off of that. IMHO it is best to use the tow hook brackets as a building base because they tie the rad cradle into the unibody rails to give as much support as possible and they were engineered to take the stress that pulling on the unibody causes.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline   Reply With Quote
Old 11-11-2007, 06:49 PM   #5
tirus89
Sorry, I was a bit giddy this morning
Thanks for the help, now to find my Dremel...
Old 11-11-2007, 08:52 PM   #6
footinmouth47
i found a sawzall works wounders. a dremel is very slow if you are impatient like the rest of us (which it looks like you are). good luck and dont let anyone get you down with design isues unless they have done better themselvs, in that case they should have helped you alread. i used 1/4 and it is beffy, i would consider going thiner on the outside to reduce weight, but keep the 1/4 in the center for strength. good luck.
her is mine if it helps i still need to cut off the metal of stock one on the sides where it is showing but you get the point
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline   Reply With Quote
Old 11-11-2007, 08:56 PM   #7
tirus89
Well, I dont own a sawzall (wish i did) so either Dremel or Hacksaw blade will have to do, i'll do it like saturday morning because I have school + work all week. Then i'll find some 1/4 to make some mounting brackets out of.
footinmouth47, do/did you have any drawings or picture that I could take a peek at? If you do that would be great!
Thanks!
Old 11-11-2007, 09:00 PM   #8
That Guy
Greg
don't you usually remove the factory bumper when installing aftermarket?
94 XJ 4.5" D30 aussie/8.25 welded 4:10's 33's
94 ZJ 5.2 3" 31's
[url]www.undergroundjeeps.net[/url]
That Guy is offline   Reply With Quote
Old 11-11-2007, 10:38 PM   #9
Darthteddy
1955 M-38
He doesnt mean the bumper....I think he means the sheet metal from the unibdy that you can see on the lower edges of the new bumper.
Old 11-12-2007, 10:38 AM   #10
footinmouth47
thats exactly what i meant. it is like a metal bumper under the plastic one.
no i dont really have any drawings but i used 1/4 by 6 inch wide, if i did it over i would have put a 2or 3 inch vetical piece between the horizantal and undercut piece just to coever up more and help mount the winch. one thing you may have is a jigsaw with a metal blad could work if you have one or know someone who does.
this gap behind the winch was not planed for and im still thinking of a way to get rid of it i have some ideas but nothing solid yet
Greg
Old 11-12-2007, 10:45 AM   #11
sandman
greg, i never saw a done pic, what did you end up doing with all that metal behind the bumper?
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 11-12-2007, 10:50 AM   #12
footinmouth47
i havent done anything yet but i recently saw a pic where all of that had been removed so i feal confident cutting it out and might do it this weekend. i just didnt know if it was structural and now i know its not so we shal see what happens, i might just get that bloodlust for takingout sheat metal and do the fenders too.
Greg
Old 11-12-2007, 11:21 AM   #13
Colorado 5.9
I assume you'll be flipping the charcloe camester too.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Latest Pics
Colorado 5.9 is offline   Reply With Quote
Old 11-12-2007, 02:46 PM   #14
tirus89
I like that design Greg, but I want mine to go a little lower than yours. What did you use for the core or middle of your bumper for support? Sorry for all the questions, I'm just trying to learn from other people.
Also, what does Trouble Maker mean by "factory tow hook brackets"? Little confused on that.
Old 11-12-2007, 05:37 PM   #15
Trouble Maker
http://www.lovewellfence.com/zj/towhook/
You can see them towards the bottom of the page in the link. They bolt on with 4 bolts on the frame rails and 2 bolts on the core support on each side. The factory ones come with a plate with the nuts welded on that slips into the frame rail. I used 4" x 1/4" flat bar sandwiched vertically and extended forward enough to weld a plate to to support the winch. I welded my winch plate across the bottom of the flat bars and notched and formed 1/8" x 6" rectangular tube for the wings on each side.
Russ
Glock Forum
