zj front axle assembly help asap - JeepForum.com
post #1 of 5 Old 01-24-2014, 11:27 AM Thread Starter
jeep93GCL
Hello jeep fans
So I been have trouble find a front axle asssemble for my jeep for a while I was woundering if I can get a jeep cherokee front end with the same gear ratio can work on my jeep.....
jeep93GCL is offline
post #2 of 5 Old 01-24-2014, 01:13 PM
Technohead
Yes. At stock ride height the high-pinion Cherokee axle may have some intereference issues.
I don't understand why you are having trouble finding an axle from a Grand Cherokee. They should be a dime a dozen.
-Eric
Technohead is offline
post #3 of 5 Old 01-24-2014, 01:32 PM
FastSUV
what years of HP D30's will work for ZJ? My ABS module is already broken but I'd still like to know all years that have ABS vs not?
ZJ - 5.9 Limited
WJ - '04 4.7 Laredo
WJ - '04 4.7 H.O. Freedom
WJ - '04 Overland
FastSUV is offline
post #4 of 5 Old 01-24-2014, 04:15 PM
shaban
I've been able to find some 96 XJ with HP D30 and ABS, mostly on limited models I'd say (leather seats)
However I've had problems with driveshaft rubbing against tranny lines on big bumps (no lift on my rig).
You can also swap in the knuckles, even if the axe doesn't have ABS, I believe knuckles and bolt-on ABS wire holders are the only differences.
shaban is offline
post #5 of 5 Old 01-25-2014, 09:41 AM
OverlandZJ
Good point..
You want 91+ XJ D30 knuckles to get the 1 piece style. Older XJ knuckles are different with having a bolt on caliper mount. By using the newer style you'll be able to reuse the ZJ unit bearings and brake assemblies if needed.
OverlandZJ is offline
