ZJ Forum FAQ's *READ THIS BEFORE YOU POST*
| Spartan Lockers FREE SHIPPING Excellent Prices | Black Magic Brakes - 5% Off, No Minimum Purchase Required | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- |
#1 | |
Infowars.com
INDEX
Frequently Asked Questions Vehicle Specs Commonly Used Links JeepForum.com Frequently Asked Questions
#3 |
Infowars.com
Vehicle Specs
ZJ Trim Models Listed from lowest priced to highest. 1993- Base, Laredo, Grand Wagoneer, Limited, 1994- SE, Laredo, Limited 1995- SE, Laredo, Limited, Orvis Limited 1996- Laredo, Limited 1997- Laredo, Tsi, Limited 1998- Laredo, Tsi, Limited, 5.9 Limited Updates: 1994 - Limited gets rear disc brakes instead of drums used on all 1993, and 1994 Laredo Models. 1995- 2WD is offered in Limited trim, disc brakes for all trim models. 1996- 2WD is offered in both Laredo and Limited, 6 and 8 cylinder models. 1998- 5.9 Limited is offered, and only has a single year of production. Jeep ZJ Produced from 1993-1995 Exterior Dimensions: Length: 176.7 in. Width: 69.2 in. Height: 64.9 in. Wheel Base: 105.9 in. Ground Clearance: 8.2 in. Curb Weight: 3574 lbs Interior Dimensions: Front Head Room: 39 in. Front Hip Room: 56.9 in. Front Shoulder Room: 58.2 in. Rear Head Room: 39 in. Rear Shoulder Room: 57.6 in. Rear Hip Room: 49.3 in. Front Leg Room: 40.8 in. Rear Leg Room: 35.7 in. Luggage Capacity: 40.1 cu. ft. Maximum Cargo Capacity: 80 cu. ft. Maximum Seating: 5 Performance: Base Number of Cylinders: 6 Base Engine Size: 4 liters Base Engine Type: Inline 6 Horsepower: 190 hp Max Horsepower: 4750 rpm Torque: 225 ft-lbs. Max Torque: 4000 rpm Maximum Payload: 1150 lbs. Maximum Towing Capacity: 5000 lbs. Drive Type: RWD Turning Circle: 36.6 ft. Optional Engine - 5.2 MPI V8 (MPI stands for Multi-Port Injection) Horsepower:220 Fuel Data: Fuel Tank Capacity: 23 gal. EPA Mileage Estimates: (City/Highway) for 6cyl Manual: 16 mpg / 21 mpg Automatic: : 15 mpg / 20 mpg Range in Miles: (City/Highway) Automatic: 345 mi. / 460 mi. Manual: 368 mi. / 483 mi. 1996-98 ZJ Dimension changes - (If not shown, it did not change) Exterior: Length: 177.2 in. Width: 69.3 in. Height: 64.9 in. Wheel Base: 105.9 in. Ground Clearance: 7.7 in. Curb Weight: 3926 lbs. Interior: Front Head Room: 38.9 in. Front Hip Room: 56.7 in. Front Shoulder Room: 59.2 in. Rear Head Room: 39 in. Rear Shoulder Room: 57.6 in. Rear Hip Room: 49.3 in. Front Leg Room: 40.9 in. Rear Leg Room: 35.7 in. Luggage Capacity: 40.9 cu. ft. Maximum Cargo Capacity: 79 cu. ft. Maximum Seating: 5 Performance for 6 cyl: Acceleration (0-60 mph): 8.6 sec. Braking Distance: 138 ft. Road Holding Index: .75 g Base Number of Cylinders: 6 Base Engine Size: 4 liters Base Engine Type: Inline 6 Horsepower: 185 hp Max Horsepower: 4600 rpm Torque: 220 ft-lbs. Max Torque: 2400 rpm Maximum Payload: 1150 lbs. Turning Circle: 37.5 ft. 1998 5.9 Limited Performance: (Available only in 1998) Performance: Acceleration (0-60 mph): 7.1 sec. Braking Distance: 135 ft. Road Holding Index: .75 g Base Number of Cylinders: 8 Base Engine Size: 5.9 liters Base Engine Type: V8 Horsepower: 245 hp Max Horsepower: 4000 rpm Torque: 345 ft-lbs. Max Torque: 3200 rpm Maximum Payload: 1150 lbs. Maximum Towing Capacity: 5000 lbs. Drive Type: 4WD Turning Circle: 37.2 ft. Fuel Data Fuel Tank Capacity: 23 gal. EPA Mileage Estimates: (City/Highway) Automatic: : 13 mpg / 16 mpg Range in Miles: (City/Highway) Automatic: 299 mi. / 368 mi. ZJ Axle, Transmission, Transfercase Info Axles: 93-98 I6 Grand Cherokee's D30 low pinion front axle
Dana 30 low pinion front axle
D44a "aluminum center section" rear axle
NOTE: NP stands for New Process, NV stands for New Venture. They switched names in the 90s for an unknown reason, but are the same company. NP242 used on I6 ZJs and WJs - This is known as SelecTrac NOTE: 93-94 V8 ZJ's had option of the NP242 Selec-Trac t-case. NP249 used on all V8 ZJs and was optional on 6 cylinder models - This is known as QuadraTrac. NP 231 used on various "heavy duty" ZJ - known as Command-Trac Also in 93-94 NP231 Command Trac was available with the I6's in SE's and Laredo 's. Transmissions 46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines. 44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines. 42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines. 46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines AW-4: 4 spd. automatic transmission used in some 1993 Jeep Grand Cherokee's with 4.0L engines. |
#4 |
Infowars.com
Commonly Used Links
![]() Hard-KOR Jeep Accessories by KevinsOffroad.com for Grand Cherokee, Wrangler, Liberty , Commander, and Cherokee IRON ROCK OFF ROAD Jeep Lift Kits and Suspension Products direct from Rubicon Express ZJ XJ WJ WK MJ TJ - Jeep Grand Cherokee and Cherokee SPECIALISTS! Rustys Offroad Clayton Off Road - Jeep Lift Kits - Jeep Cherokee Lift Kits - Jeep Wrangler Lift Kits - Jeep Suspension Lift Kits MallCrawlin HomePage www.nagca.com JeepWorld.com - Mopar Equipment - Jeep Parts and Accessories. Jeeps Are Us - Mopar Equipment - Jeep Parts and Accessories. Budget Boost Installation: |
#5 |
Infowars.com
How do I use the Search Function? Avatars, IMG tag, Custom Title and Attachments JeepForum.com Rules |
| Tags |
| axle, backspacing, differential, engine, faq, grand cherokee, lift, suspension, tire, transfercase, transmission, wj, write-ups, zj |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
