-   -   ZJ Forum FAQ's *READ THIS BEFORE YOU POST* (http://www.jeepforum.com/forum/f13/zj-forum-faqs-read-before-you-post-880249/)
Jones 10-16-2009 02:08 AM
INDEX
Frequently Asked Questions
Vehicle Specs
Commonly Used Links
JeepForum.com Frequently Asked Questions
Jones 10-16-2009 02:09 AM
Frequently Asked Questions / Write-ups
Suspension / Tires
Tire Size vs. Amount of Lift Chart
http://i986.photobucket.com/albums/a...3/TvLchart.gif
Common Budget Boost "BB" Questions
What do I need for a 5"+ lift?
Puma's answer to the ZJ front swaybar issue!
What is Death Wobble and How Can I Cure It?
How do I assemble Addco swaybar end links?
Swaybar Endlink Info
Axles / Differentials
How to replace an axle shaft and/or a wheel hub bearing assembly
How to replace Ball Joints
D44a Aussie Locker Install
Warped Rotors (Front end vibrates when I apply the brakes)
A really Good Gear ratio and transmission calculator
Rebuilding a D44a axle
Regearing Chart
http://i986.photobucket.com/albums/a...Ratiochart.jpg
Engine / Transmission / Transfercase
46RE Rebuild
5.2 to 5.9 Swap
ZJ Diagnostic codes
There is oil in my breather.
4.0L Oil Filter Adapter O-ring replacement.
Taurus E-Fan Conversion
NP249, NV249 Viscous Coupling
NP249 TO NP242 (or 231) SWAP
NP242 Rebuild Tutorial
ZJ Transmission Band Adjustment
Swapping a 42RE for an AX-15
ZJ Fuse Panel Diagram / Power Distribution Center / PDC
I just regeared or changed tire size on my ZJ, what speedometer gear do I need now?
How do I replace the front crankshaft oil seal?
How do I clean the IAC (Idle Air Control) valve?
Superlift Truespeed
Driveshaft Specs
Saginaw Steering Box/Gear Rebuild
How To Rebuild Your Saginaw ZJ Steering Gear
Steering Box Adjustments - How To Fix your Floppy Steering
Electrical
How to change dash light on 93-98 ZJ
My backup lights don't work or work intermittently.
Power windows/locks stop working
How Can I wire Fog lights up in a ZJ that didn't already have factory Fogs?
Programming 93-95 ZJ's IR Keyless Entry Remotes
Climate Control Diagnostic Mode
Miscellaneous
Passenger Floor Board Wet?
Swampy Bypass fuel pump system conversion
ZJ Fender Trimming
Grand Cherokee Most Common Mods
Commonly Used Acronyms
How Do I Reset the Miles to Service Display?
What are the Technical Service Bulletins for my Jeep?
Where can I request my buildsheet?
License Plate Mount for Roller Fairleads
Custom Bumpers
Fluids for the Grand Cherokee
Fix that sagging door from 95GC
Overhead console install on 93-95 ZJs
Replacing the lift struts
How to replace a ZJ sunroof seal
How to remove cladding on 93-98 ZJ's
Double cardan rebuild (writeup w/pics)
How to remove the dash in a 1996-1998. Heater core replacement. (writeup w/pics)
Jones 10-16-2009 02:10 AM
Vehicle Specs
ZJ Trim Models
Listed from lowest priced to highest.
1993- Base, Laredo, Grand Wagoneer, Limited,
1994- SE, Laredo, Limited
1995- SE, Laredo, Limited, Orvis Limited
1996- Laredo, Limited
1997- Laredo, Tsi, Limited
1998- Laredo, Tsi, Limited, 5.9 Limited
Updates:
1994 - Limited gets rear disc brakes instead of drums used on all 1993, and 1994 Laredo Models.
1995- 2WD is offered in Limited trim, disc brakes for all trim models.
1996- 2WD is offered in both Laredo and Limited, 6 and 8 cylinder models.
1998- 5.9 Limited is offered, and only has a single year of production.
Jeep ZJ Produced from 1993-1995
Exterior Dimensions:
Length: 176.7 in. Width: 69.2 in.
Height: 64.9 in. Wheel Base: 105.9 in.
Ground Clearance: 8.2 in. Curb Weight: 3574 lbs
Interior Dimensions:
Front Head Room: 39 in. Front Hip Room: 56.9 in.
Front Shoulder Room: 58.2 in. Rear Head Room: 39 in.
Rear Shoulder Room: 57.6 in. Rear Hip Room: 49.3 in.
Front Leg Room: 40.8 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.1 cu. ft. Maximum Cargo Capacity: 80 cu. ft.
Maximum Seating: 5
Performance:
Base Number of Cylinders: 6 Base Engine Size: 4 liters
Base Engine Type: Inline 6 Horsepower: 190 hp
Max Horsepower: 4750 rpm Torque: 225 ft-lbs.
Max Torque: 4000 rpm Maximum Payload: 1150 lbs.
Maximum Towing Capacity: 5000 lbs. Drive Type: RWD
Turning Circle: 36.6 ft.
Optional Engine - 5.2 MPI V8 (MPI stands for Multi-Port Injection)
Horsepower:220
Fuel Data:
Fuel Tank Capacity: 23 gal.
EPA Mileage Estimates: (City/Highway) for 6cyl
Manual: 16 mpg / 21 mpg Automatic: : 15 mpg / 20 mpg
Range in Miles: (City/Highway)
Automatic: 345 mi. / 460 mi. Manual: 368 mi. / 483 mi.
1996-98 ZJ Dimension changes - (If not shown, it did not change)
Exterior:
Length: 177.2 in. Width: 69.3 in.
Ground Clearance: 7.7 in. Curb Weight: 3926 lbs.
Interior:
Front Head Room: 38.9 in. Front Hip Room: 56.7 in.
Front Shoulder Room: 59.2 in. Rear Head Room: 39 in.
Front Leg Room: 40.9 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.9 cu. ft. Maximum Cargo Capacity: 79 cu. ft.
Maximum Seating: 5
Performance for 6 cyl:
Acceleration (0-60 mph): 8.6 sec. Braking Distance: 138 ft.
Road Holding Index: .75 g Base Number of Cylinders: 6
Base Engine Size: 4 liters Base Engine Type: Inline 6
Horsepower: 185 hp Max Horsepower: 4600 rpm
Torque: 220 ft-lbs. Max Torque: 2400 rpm
Maximum Payload: 1150 lbs. Turning Circle: 37.5 ft.
1998 5.9 Limited Performance: (Available only in 1998)
Performance:
Acceleration (0-60 mph): 7.1 sec. Braking Distance: 135 ft.
Road Holding Index: .75 g Base Number of Cylinders: 8
Base Engine Size: 5.9 liters Base Engine Type: V8
Horsepower: 245 hp Max Horsepower: 4000 rpm
Torque: 345 ft-lbs. Max Torque: 3200 rpm
Maximum Payload: 1150 lbs. Maximum Towing Capacity: 5000 lbs.
Drive Type: 4WD Turning Circle: 37.2 ft.
Fuel Data
Automatic: : 13 mpg / 16 mpg
Automatic: 299 mi. / 368 mi.
ZJ Axle, Transmission, Transfercase Info
Axles:
93-98 I6 Grand Cherokee's
D30 low pinion front axle
  • Differential Location: Drivers side
  • Stock axle splines: 27 (upgradeable to 30 splines)
  • Lug Pattern: 5 on 4.5"
  • Width: 60.5" from wheel mounting surface to wheel mounting surface
  • Notes: Stronger than earlier D30's. Not a bad axle with 33" or smaller tires. The u-joints are the main weak point but can be easily upgraded. 93-95 uses "cj style, long pinion" gears. 96-98 uses "tj style, short pinion" gears.
D35 c-clip rear axle
  • Differential Location: Centered
  • Stock D35 axle splines: 27 (upgradeable to 30 splines)
  • Notes: Not a bad axle with 33" or smaller tires if left open. Many people upgrade this axle with 30 spline axles and lockers. However you'd be better off swapping in a stronger axle like a Dana 44a or Ford 8.8. The weak part of this axle is the axle tubes. Under extreme pressure they flex which results in broken axles or pinion failures.
93-98 V8 (5.2L or 5.9L) Grand Cherokee's
Dana 30 low pinion front axle
  • Notes: Stronger than earlier D30's. Not a bad axle with 33" or smaller tires. The u-joints are the main weak point but can be easily upgraded. 96-98 uses "tj style, short pinion gears" 93-95 uses "cj style, long pinion" gears.
96-98 ONLY
D44a "aluminum center section" rear axle
  • Stock axle splines: 30 spline shafts, no upgrades to spline count available
  • Notes for D44a: Not a bad axle with 33-35" tires, some care needed for the larger end, has been known to handle 37's with care. The aftermarket support is very limited for this axle due to the aluminum center section. The center section is very similar to the unit in the corvette. Many people replace the axle due to the limited gear ratio's available and the extremely limited availability of any traction device such as a locker.
Transfercases:
NOTE: NP stands for New Process, NV stands for New Venture. They switched names in the 90s for an unknown reason, but are the same company.
NP242 used on I6 ZJs and WJs - This is known as SelecTrac NOTE: 93-94 V8 ZJ's had option of the NP242 Selec-Trac t-case.
NP249 used on all V8 ZJs and was optional on 6 cylinder models - This is known as QuadraTrac.
NP 231 used on various "heavy duty" ZJ - known as Command-Trac
Also in 93-94 NP231 Command Trac was available with the I6's in SE's and Laredo 's.
Transmissions
46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines.
44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines.
42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines
AW-4: 4 spd. automatic transmission used in some 1993 Jeep Grand Cherokee's with 4.0L engines.
Commonly Used Links
http://i131.photobucket.com/albums/p.../JEEPWIKI4.jpg
Hard-KOR Jeep Accessories by KevinsOffroad.com for Grand Cherokee, Wrangler, Liberty , Commander, and Cherokee
IRON ROCK OFF ROAD
Jeep Lift Kits and Suspension Products direct from Rubicon Express
ZJ XJ WJ WK MJ TJ - Jeep Grand Cherokee and Cherokee SPECIALISTS!
Rustys Offroad
Clayton Off Road - Jeep Lift Kits - Jeep Cherokee Lift Kits - Jeep Wrangler Lift Kits - Jeep Suspension Lift Kits
MallCrawlin HomePage
www.nagca.com
JeepWorld.com - Mopar Equipment - Jeep Parts and Accessories.
Jeeps Are Us - Mopar Equipment - Jeep Parts and Accessories.
Budget Boost Installation:
Jones 10-16-2009 02:11 AM
How do I use the Search Function?
Avatars, IMG tag, Custom Title and Attachments
JeepForum.com Rules
Texas ZJ1 01-09-2013 10:22 AM
How ro replace front axle assembly thanks ZJMatt
How-To Write-up: Replace front axle assembly
This process and pics were from a Grand Cherokee (actually two different ones), but the process would be similar on most coil-sprung solid front axle vehicles. Cherokee and TJ Wrangler would be nearly identical.
I'm in the process of swapping out my front and rear axles in my jeep, so I figured why not take pictures and do a write-up as I go. If anyone finds anything I forgot or should elaborate on, let me know
Step 0: Pressure wash your jeep. I had been out wheeling on a friend's property the day before I started this project, and as you can tell in some of the pictures, it was muddy. The mud made it a lot harder to work and very annoying when chunks fall in your face.
Tools needed for the entire process:
Floor Jack
Jack stands
Impact gun
Ratchets of various sizes (1/4", 3/8", 1/2" plus very long-handled 1/2" for extra leverage)
Extensions to go on those ratchets.
Vice Grips
Pliers
Big hammer (commonly referred to in other tutorials as a BFH)
Pry bars
Punch or cam bar
Pickle Fork
Spring compressor & proper size socket
8mm wrench
13mm wrench
14mm wrench
22mm wrench
8mm socket
13mm socket (both deep & shallow)
15mm socket (both deep & shallow)
18mm socket
19mm socket (or whatever size your lug nuts are)
22mm socket
T-50 torx bit
Ok, on to the real process... You can do these steps in most any order. After doing it twice, this is the way I would go about doing it a third time (not necessarily the way I did it as you can see in some of the pics). Also, air tools make this project MUCH easier! I couldn't imagine trying to do it without them. Another reccomendation is to always use 6-point wrenches and sockets if you can, especially if the bolts may be rusty. 12 point strips heads much easier and that's never a good thing.
1. Jack up the jeep as high as possible. Place jack stands in a safe and secure location under the body / frame (NOT the axle - we need to separate the body from the axle). I would reccomend on the body right by the control arm mounts. I would also reccomend leaving the floor jack under the axle for at least part of this procedure, since the axle could drop unexpectedly. Don't leave it jacked up, just leave it under there for support.
Tools needed: Floor jack, jack stands.
This image has been resized. Click this bar to view the full image.
2. Remove your tires.
Tools needed: 19mm socket (or whatever size your lug nuts are), impact gun.
2. Disconnect your sway bar. I don't have a picture, but there should be a 15mm nut at the top of each side's end link. Then use a pry bar to separate the sway bar from the link, so the sway bar is flipped upwards.
Note: This is the main step why I said to keep support under your axle. When you pull the front sway bar, the axle will have about 4 more inches of extra travel (assuming your shocks allow for it).
Tools needed: 15mm socket, impact gun or long-handled ratchet/breaker bar
3. Loosen or remove your lower spring retainers. Didn't get a pic of this one, but they're at the bottom of the spring where it goes into the axle. Each side has one 13mm bolt and it's just a tab that swings over your spring to hold it in place in the bottom. They don't need to come OFF, but loose enough that you can twist your spring once we take pressure off of it.
Tools needed: 13mm wrench
4. Disconnect your shocks. On the Grand Cherokee, I've found that it's easiest to disconnect the passenger's side from the top, since the lower control arm mount makes it difficult to get at the bottom nuts. On the driver's side, it's easier to disconnect it from the bottom, since the brake master cylinder is in the way of the top nut. Other vehicles may be different. So both times, I ended up with the passenger's side shock still attached to the axle, and the driver's side still attached to the body. Obviously if you're replacing your shocks, you'll need to disconnect them at both ends, but my shocks are fine so leaving the driver's side attached to the body was no problem.
Note: When pulling the top nut, it is much easier to have two people. The entire shaft of the shock will try to turn, so you need to grab it with vice grips. If you're flexible enough, you can hold it and turn the nut at the same time but it's not a fun position.
Tools needed: 13mm wrench, 13mm deep well socket, 15mm socket deep well socket, extensions, ratchet, vice grips.
Picture of the lower bolts. There is also a nut on the bottom side of this, 13mm. Easier to get on with a deep well socket. I used a wrench to hold the heads.
Picture of the top nut, passenger's side. This is up in the engine bay:
5. Disconnect your front driveshaft. On a jeep you should have one of two style driveshafts. CV-joint, with a 6-bolt flange yoke, or U-joint style (preferably), with 4 bolts and straps. Either way, the bolts will be 8mm. Once you remove the bolts (and straps), stand out of the way and hit it with a big hammer, in a place that won't cause damage to the shaft. That should pop it off the yoke from the pinion.
Tools needed: 8mm socket & ratchet, or 8mm wrench. Big hammer.
Picture 1: CV style shaft (bolts removed).
Picture 2: U-Joint style shaft.
6. Disconnect your brake lines. I reccomend doing this now, because soon we will begin really dropping the axle, and you don't want to stretch and possibly break one of your brake lines. We're looking at the bolt with the "P" on it, on the back side of the caliper. Once you remove your lines, fluid will start to come out of both the lines and the caliper. I would reccomend hanging your lines in one of the holes in the frame, to stop excessive draining of the system.
Tools needed: 14mm wrench
7. Remove your lower control arms, by the front bolt. If you're replacing them (highly reccomended when lifting your jeep and/or if you plan on wheeling it), you'll obviously want to disconnect them at both ends, but as you can see I already have aftermarket arms that I'm keeping. This is probably the most difficult / annoying step of the process, getting the bolts out, especially if you have OEM arms (in that case, your bushings are probably shot and will turn with the bolt). Once you get the nut off the back side, you'll also need to get the washer off. Then tap it through with a hammer and once you get it back into the hole, take a punch or cam bar and put in the hole and tap that. Throughout this process you'll want to experiment with raising and lowering the jack, and turning the steering wheel, in order to try to take tension off the bolt. Just keep playing with it and it'll come out eventually. Once you remove the bolts, pry on the arm a little and it should separate out of the axle, and should swing out of the way as pictured.
Tools needed: 22mm socket, VERY long handled ratchet/breaker bar, impact gun, 22mm wrench, big hammer, punch/cam bar.
8. Remove your coil springs. Lower the jack down until it is no longer holding up on the axle. You may be able to apply a little more pressure on the axle and twist and pull your spring out. If not, you will need to use a spring compressor.
Tools needed: Coil spring compressor, appropriate sized socket and ratchet (mine was 22mm).
8. Disconnect your upper control arms. One side is a 15mm nut, the other is a T50 torx bit. These should come out easier than the lowers, but follow the same process.
Tools needed: 15mm socket, extensions, impact gun, T50 torx bit and ratchet, big hammer, punch/cam bar.
9. Remove your track bar bolt at the axle. There is a nut on the back side with a tab that will hold the nut in place on its own. You can see it's the hole with clean metal around it here. The lower arm in the picture, is the track bar after it's been disconnected:
Tools needed: 15mm socket, impact gun.
10. Disconnect your steering. You can either pull it all off at the pitman arm, or disconnect the drag link, stabilizer, and tie rod separately, which is the way I did it. Once you get the castle nuts off, take a pickle fork and tap it in with your hammer to separate them.
Tools needed: pliers, 18mm socket, 15mm socket, impact gun, pickle fork, big hammer
Disconnecting steering stabilizer at the axle:
Disconnecting drag link from passenger's knuckle:
Disconnecting tie rod from drag link:
11. Remove your ABS sensors. These are on the back side of the hub and read by a magnet off of the splines on your axle shaft. This is the easiest step and I saved it for last. Each has a single 8mm bolt holding it in. Then the wires are attached by rubber grommets in 3 spots along the axle - pop those out.
Tools needed: 8mm socket and ratchet.
12. Lower your jack down and pull the axle out from underneath the jeep.
13. The most time consuming step. Reverse procedure to re-install new axle.
Here is the link to the write up with pics.
http://www.jeepforum.com/forum/f13/h...embly-1461082/
The daily driver and adventure machine:
1995 ZJ, 3" coil spacer lift, 32x11.5 BFG Muds, ARB front bumper, and a free pinstriping job.
Texas ZJ1 06-23-2013 07:22 AM
ZJ engine stalling? Check out these common fixes!
http://www.jeepforum.com/forum/f13/1...talls-1407423/
Texas ZJ1 01-17-2015 08:53 PM
new stuff from Coralman
Originally Posted by coralman (Post 26861169)
Ok, I've realized I can't get this all done in one sitting:).Once it starts please don't post to the thread cause it will confuse me,lol.
Realize these are just links I have ran across doing research. Some ebay links may be expired but if the description is still available you may be still able to get part numbers and average pricing ideas. I can't be held responsible for any info in them. They are not definitive list so if leave something out let me know. They might save you a little time when doing your own project. Its gonna be a work in progress so check back once in awhile. I am including links to my projects as well.
My projects
http://www.jeepforum.com/forum/f13/c...build-1344601/ rear axle rebuib
http://www.jeepforum.com/forum/f13/h...orial-2682426/ head swap,cam,gears,injectors,exhaust
http://www.jeepforum.com/forum/f13/f...-swap-2589754/ exhaust installed
http://www.jeepforum.com/forum/f13/a...-pics-1467016/ abs module repair
http://www.jeepforum.com/forum/f13/p...-gear-2667418/ installing steering gear
http://www.jeepforum.com/forum/f13/c...build-1828106/ a/c housing rebuild
http://www.jeepforum.com/forum/f13/c...build-1518536/ front suspension and steering
http://www.jeepforum.com/forum/f13/9...ement-1587873/ motor mount replace
http://www.jeepforum.com/forum/f13/m...rsion-2013761/ led heater control
http://www.jeepforum.com/forum/f13/b...t-pod-2219577/ led wiper pod
http://www.jeepforum.com/forum/f13/b...-pics-1229778/ swapping door trim
http://www.jeepforum.com/forum/f13/n...-wire-1572698/ wire splicing
http://www.jeepforum.com/forum/f13/9...heavy-1587401/ trans mount replace
http://www.jeepforum.com/forum/f13/p...place-1556291/ lock motor replace
http://www.jeepforum.com/forum/f13/h.../#post27001881 steering column removal
http://www.jeepforum.com/forum/f13/t.../#post27217562 testing a heater core
PCM
http://www.jeepforum.com/forum/f13/1...talls-1407423/ the bible for stalls
http://www.jeepforum.com/forum/f13/9...l#post13649055 pcm resolder
http://dodgeram.info/tsb/1997/08-01-97.htm pcm connector repair
http://www.ellsworth.com/dow-corning...een-210ml-kit/ potting compound sub
http://www.mouser.com/search/refine....e&Ntk=P_MarCom pcm pin
http://www.jeepforum.com/forum/f13/c...downs-1089895/ replace pcm pin
http://dodgeram.info/tsb/1997/08-01-97.htm chrysler tsb pins
http://www.jeepforum.com/forum/f13/p...-clear-529400/ clearing pcm memory
http://www.drewtech.com/technician/support/videos.html pcm pass through
http://reviews.ebay.com/Scan-Tools-V...00000011027118 program basics
http://www.aa1car.com/library/2004/c...ailability.pdf pcm part numbers
http://www.codeobd.com/j2534-ecu-reprogrammer.php pcm sho nuf progam
http://www.aa1car.com/library/2004/us10430.htm flash procedure
http://www.drewtech.com/technician/support/videos.html reflashing using cardac
http://www.aldlcable.com/connectors.asp obd connectors of all types
http://www.all-spec.com/search?keywo...FYM8aQodfKwAUg Deoxit pin cleaner
http://mdhmotors.com/can-communicati...k-protocols/2/ PCM CCD communication
BODY CONTROL MODULE
http://buy1.snapon.com/products/diag...0AppendixB.pdf
STEERING BOX
http://www.jeepforum.com/forum/f13/h...-gear-1287129/ tear down
http://www.jeepforum.com/forum/f13/h...-gear-1287958/ rebuild
http://www.youtube.com/watch?v=UJ-89YhvAXU video
http://members.shaw.ca/pavelb2/ssbRebuild.html rebuild pictorial
http://www.rockauto.com/catalog/more...615&cc=1180112 rebuild kit with bearings
http://www.fourwheeler.com/how-to/tr...oto-01.html#34 pictorial
http://www.pirate4x4.com/forum/gener...build-how.html pictorial
http://www.chevelles.com/techref/RBGStrgGearBlowUp.jpg parts pic
http://www.chevelles.com/techref/shea_2.html factory
http://selectric.org/manuals/sag800/index.html factory
http://vintage.mitchell1.com/PClubDa...V2D8213067.pdf factory
http://forums.off-road.com/jeep-shor...ginaw-box.html info
http://www.newgmparts.com/oe-gm/7826850 thrust brg
http://www.powersteering.com/pdf/PowerSteering0606.pdf pictorial
http://www.vxb.com/page/bearings/CTG...NeedleBearings supplier
http://www.youtube.com/watch?v=0F2eHlRnZfk video
http://www.gmpartsdirect.com/results...number=7815988 ball kit
http://www.gmtruckclub.com/forum/thr...-rings.103687/ oring
http://www.jeepforum.com/forum/f9/tj...stion-1525007/ oring
http://www.plews-edelmann.com/repair...ings/?F_Sort=2 oring
http://stores.ebay.com/locateballbea...p2047675.l2563 brg supply
http://www.summitracing.com/parts/ag...grand-cherokee agr box
http://www.prosteering.com/ld_gear_parts.htm parts list
http://www.jeepforum.com/forum/f13/w...e-nut-1378473/ pitman nut
http://www.ebay.com/itm/Steering-Gea...cb4457&vxp=mtr
http://www.ebay.com/itm/Steering-Gea...1c9391&vxp=mtr
http://www.jeepforum.com/forum/f13/i...aring-1461775/ SLH bearing source Pitman arm bearing
WIRE<WIRING<TOOL
http://www.litz-wire.com/pdf%20files..._2.4.27.07.pdf wire gauge
http://crimpsupply.com/wire supply
http://www.amazon.com/Lisle-57750-Wi...=pd_sim_auto_4 tool
http://connectors.dcctools.com/parts_list.htm MOPAR CRIMPS
http://www.painlessperformance.com/PDFCatalog/index.php
http://connectors.dcctools.com/home.htm
MOPAR CONNECTORS
http://autoelectrical.com/ supply
http://www.kayjayco.com/catPWireGXLTXL.htm supply
http://www.awcwire.com/FAQ-Automotive-Wire.aspx info
http://www.wiringproducts.com/conten...d=40409.042361 supply
http://www.waytekwire.com/products/ supply
http://connectors.dcctools.com/splicing_procedure.htm
http://www.handsontools.com/SG-Tool-...ls_p_2445.html crimper
http://www.cabletiesandmore.com/amer...foot-p-134.php colored heat shrink
http://stores.ebay.com/4rcustoms?_trksid=p2047675.l2563 striped wire
http://www.amazon.com/Lisle-57750-Wi...=pd_sim_auto_4 pin tools
REGEARING AXLE
http://www2.dana.com/expertforms/deabill.aspx parts
http://www.drivetrain.com/parts_cata...end_parts.html parts
http://www2.dana.com/pdf/X510-9.pdf dana axle parts
http://www.timken.com/en-us/products...ence_Guide.pdf bearing cross
http://www.jeepforum.com/forum/f9/ex...thread-965764/ to learn
http://www.jeepforum.com/forum/f9/re...tj-d44-970997/
http://www2.dana.com/pdf/X5001-CVSP.pdf for a WJ
http://www.billhughes.com/dana35c/TJDana35.pdf FSM reprint
http://www.jeepforum.com/forum/f12/g...-101-a-623694/
http://www.stu-offroad.com/axle/ujoint2/ujoint-2.htm u joint
http://www.pirate4x4.com/tech/billavista/Gear_Setup/ good gear tutorial
http://www2.dana.com/pdf/X510-6.pdf 99-2011 dana jeep axle parts
http://www2.dana.com/pdf/XGI.pdf newest dana catalog takes awhile to load
http://www.drivetrainamerica.com/ good people when I used them
http://www.jeepforum.com/forum/f9/an...temps-1107353/ break in temps
4.0 ENGINE and MISC ENGINE
http://www.moparrepairconnection.com...d-78ab3de567ab diagnosing misfires by mopar
http://www.jeepforum.com/forum/f13/e...olant-1553995/ volts in coolant
http://www.aa1car.com/library/coolin..._corrosion.htm volts in coolant
http://blog.chiltondiy.com/2013/06/w...-your-vehicle/ types of antifreeze
http://dodgeram.info/tsb/1996/24-01-96a.htm
TSB VACUUM CHECK VALVE PART#
http://forum.grumpysperformance.com/...7&p=1177#p1177 rusted bolts
http://www.jeepforum.com/forum/f11/r.../#post13862867 alt rebuild
http://www.jegs.com/i/Mopar-Performa...ductId=1518360 double roller chain, instruction
http://www.jeepforum.com/forum/f13/l...4-0-a-1570841/ lifter info
http://www.summitracing.com/parts/sl...ions/year/1998 lifters
http://www.summitracing.com/parts/cr...ions/year/1998 lifters
http://www.jeepforum.com/forum/f13/c...heavy-1348138/ nicks head rebuild
http://www.mopar.com/assets/pdf/perf...g/Jeep_Ram.pdf mopar performance catalog
http://www.pirate4x4.com/tech/billav...0Abrasives.pdf head porting
http://www.melling.com/Portals/0/Siz...on%20Chart.pdf melling cam specs
http://www.fme-cat.com/Application.aspx#passengercar sealed power felpro ect e catalog
http://www.cartechbooks.com/techtips/camshafts1/ camshaft theory and operation
http://www.hotrodders.com/forum/mls-...ets-65157.html multi layer steel gasket info
http://www.greatlakes4x4.com/showthread.php?t=661 4.0 casting numbers and more
http://www.jeepstrokers.com/forum/vi...hp?f=34&t=1503 stroker info
http://search.yahoo.com/search;_ylt=...t%20procedures cylinder leak down test
http://www.walmart.com/ip/35072061?w...ok+Information
http://www.thecj2apage.com/forums/fa...opic11812.html bore oversize
http://www.omnitek.co/mellingweb/ melling factory catalog
http://www.angelfire.com/my/fan/Jeep4.0Camshafts.htm 4.0 cam specs
http://catalog.mahleclevite.com/lv/d...vtec=2248:3330 1998 4.0 engine parts
http://www.shop.505performance.com/m...m1plqscsfapp06 4.0 go fast
http://www.mellingengine.com/Portals...Rev4-12-07.pdf cam break in
http://chicagoengines.com/tech/bulle...ilt-Engine.htm engine startup info
http://www.secondchancegarage.com/public/186.cfm how to use vacuum gauge
http://www.jeep4.0performance.4mg.com/tech_specs.html 4.0 engine specifications
http://enginetechcatalog.com/Default.aspx engine tech catalog
FUEL INJECTORS AND FUEL TRIM, SENSORS
http://www.aa1car.com/library/2003/us60324.htm learning source
http://www.aa1car.com/library/fuel_trim_wellsmfg.pdf learning source
http://www.aa1car.com/library/what_is_fuel_trim.htm learning source
http://www.obdii.com/articles/Unders...n_Sensors.html 02 function
http://www.3sx.com/store/comersus_vi...?idProduct=769 02 sensor chip bypass
http://www.mrinjectorparts.com/top-feed-kits.html injector parts
http://www.jeepforum.com/forum/f13/d...56/index5.html 703 injectors
http://www.obd-codes.com/faq/fuel-trims.php more on trims
http://www.jeepforum.com/forum/f13/d...36/index5.html 703 injectors
http://www.fuelinjector.citymaker.co...low_Rates.html flow rates
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html 02 simulator
http://www.jeepforum.com/forum/f13/b...98/index6.html trouble shooting
HEADERS AND EXHAUST,INTAKE MANIFOLD
http://www.jeepforum.com/forum/f13/e...ement-1361102/ detailed
http://dailydriventj.com/forum/viewtopic.php?t=847 exhaust manifold replace detailed
http://www.go.jeep-xj.info/HowtoExhaustHeaders.htm another how to
http://www.heatshieldproducts.com/pr...o-shield/51/21 heat shields
http://www.jeepforum.com/forum/f13/w...index1009.html torchd 2.5 inch exhaust
http://catalog.remflex.com/ remflex exhaust gaskets good gaskets
http://www.jeepforum.com/forum/f11/h...stion-1000816/ cracked apn
http://www.ineedparts.com/apn-jeep-e...-manifold.html
http://www.jeepforum.com/forum/f13/9...-swap-1234191/ wj to zj exhaust swap
http://www.go.jeep-xj.info/HowtoIntakeManifold1.htm wj manifold swap info
http://www.naxja.org/forum/showthread.php?t=84418 wj manifold swap
AUTO TRANSMISSION
http://www.jeepforum.com/forum/f13/t...stment-327109/ how to
http://ww2.justanswer.com/uploads/do...204539_b02.pdf TSB sloppy shifter
http://www.jeepforum.com/forum/f13/h.../#post15782997 excellent how to
http://www.bulkpart.com/transmission-cooler.html cooler recommendations
http://www.transmissionpartsusa.com/...-02200001k.htm case repair kit
http://bionicdodge.com/Download/Dodg...Adjustment.pdf TV cable adjust good article
http://www.onlinetransmissionparts.c...l--dsh-/Detail A500 42re rebuild dvd
http://www.ctpowertrain.com/a500-518...-kit-bearings/ parts
http://www.drivetrain.com/parts_cata...rhaul_kit.html parts
http://www.transmissionpartsusa.com/...-22171a02k.htm parts
http://www.transmissionpartsusa.com/...-01278301k.htm parts
http://s3.amazonaws.com/sonnax-dev/u...01K_02K-IN.pdf upgrade piston retainer
http://www.sonnax.com/pdfs/92-SonnaF...E-Normal-Poor- link to sonnax site
http://www.daccoinc.com/pdfs/catalogs/TF6_A904_A500.pdf link to dacco site, exploded diagrams
http://www.youtube.com/watch?v=6Nz_ICxyMW8 trans rebuild video
http://www.sonnax.com/parts/1763 upgrade intermediate shaft
http://www.sonnax.com/parts/1764 oversized piston retainer
http://www.sonnax.com/parts/1835 fluid flow in park
http://www.sonnax.com/parts/1851 upgrade accumulator piston
http://www.sonnax.com/parts/1859 upgrade boost spring retainer
http://www.wjjeeps.com/tsb/tsb_wj_210899.pdf TSB buzzing regulator valve
http://dnjcomponents.com/index.php billet hvy duty sensor housing
http://www.atsg.us/atsg/ Trans manuals and learning resources
http://www.digi-panel.com/trannyoil.htm expected trans oil temps and fluid life relationship
http://www.jeepsunlimited.com/forums...ebuild-my-42re number of clutches in various RE trans
http://www.jeepforum.com/forum/f13/4...torial-911009/ 46 re rebuild
http://mallcrawlin.com/forum/showthr...oler-upgrade!& filter and cooler upgrade
http://joelsgarage.blogspot.com/2008...-governor.html trans rebuilding
http://www.jeepforum.com/forum/f13/t...6/#post9286096 TV cable adjust
http://www.makcotransmissionparts.co...01/A22670H.pdf one piece input shaft whoooooeeee
http://www.centralvalvebodies.com/ valve bodies
LIGHTS AND LIGHTING
http://www.jeepforum.com/forum/f13/z...eware-1471857/
http://www.superbrightleds.com/morei...panel-led/220/ neowedge LEDS
http://www.jeepforum.com/forum/f13/9...shing-1328156/
http://www.modifiedlife.com/1997-jee...ht-bulb-sizes/ ZJ bulb sizes
http://led.linear1.org/1led.wiz LED calculator for resistors
http://www.autolumination.com/instru..._led_bulbs.htm NEO wedge bulbs
http://www.led-switch.com/ leds and switches
http://www.jeepforum.com/forum/f13/u.../#post15069043
http://www.jeepforum.com/forum/f13/e...h-mod-1281470/ aurora light mod
http://www.jeepsunlimited.com/forums...ctor-HID-Retro!
http://www.theretrofitsource.com/ projectorlighting source
http://www.autolumination.com/connectors.htm pigtails
http://www.jeepforum.com/forum/f13/h...ur-zj-1255001/
http://www.jeepforum.com/forum/f310/...cheap-1035543/ possible in a ZJ
http://www.jeepsunlimited.com/forums...-handle-cavity
http://www.jeepforum.com/forum/f13/r...-heavy-702703/
http://www.jeepforum.com/forum/f13/m...s-etc-1313573/
http://www.superbrightleds.com/cat/l...ee--/30-587--/ bulb list leds
http://www.sylvania.com/en-us/applic...el=989&make=46 sylvania bulb list
RADIO, ALARMS,REMOTE START,ELECTRICALLY OPERATED DEVICES, EFANS
http://www.jeepforum.com/forum/f13/p...45/index2.html battery drain
http://www.the12volt.com/installbay/...asp?TID=121197 interface wiring
http://www.jeepforum.com/forum/f13/t...relay-1526807/
http://www.pac-audio.com/productDeta...&CategoryID=29 wheel controls interface
http://www.oemautosound.com/p-42-pie...1995-2000.aspx
http://www.jeepforum.com/forum/f13/h...-move-1891673/ memory mirrors
http://www.jeepforum.com/forum/f13/e...l#post15804314
http://www.bulldogsecurity.com/bdnew...ngdiagrams.asp alarm remote site
http://www.jeepforum.com/forum/f13/h...iteup-1148835/ heated seat repair
http://thespeedfreaks.net/showthread...eats-fix/page4 another heated seat fix
http://www.jeepsunlimited.com/forums...erature-switch OEM? 5.9 switch
http://www.jeepforum.com/forum/f13/5...hread-1717434/ 5.9 fan switch
http://www.nagca.com/forum/showthread.php?t=49090 OE radio aux input add
The time now is 10:10 PM.
