ZJ flat-iron custom bumper - JeepForum.com
post #1 of 46 Old 06-02-2011, 11:41 PM Thread Starter
zjaholic
just built this bumper from 5/16 channel iron altogether cost under $100. welded to frame, took about 6 hours of labor(not really focusing too hard) to finish. Im pleased with it for now might run some sheet metal under to hide the radiator and give it more of a fuller look later. here are some pics from start to finish, sorry didn't include all steps and I ended up welding the mounts with more surface area touching the frame, unlike in the picture. finished it off with bedliner.
zjaholic is offline
post #2 of 46 Old 06-02-2011, 11:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Don't use those rings for recovery. You may kill someone.
ratmonkey is offline
post #3 of 46 Old 06-02-2011, 11:57 PM
freakinheep89
Aside from the rings it looks pretty good for a home built.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #4 of 46 Old 06-03-2011, 12:12 AM
NapsterZJ
It might just be the angle, but I think it hangs a little low.
Looks good though
1995 ZJ Laredo 4.0 - 5 Speed swap and 4x4 conversion, JKS KOR conversion and durometer bushings, Bilstein 5100s, fixed LCAs
DD - Stock 99 WJ 4.7 QD with flo 40
NapsterZJ is offline
post #5 of 46 Old 06-03-2011, 12:30 AM
mike_breaker_5
i would agree with heep and monkey, those rings may not be strong enough for recovery points. if they were brought through from the back, welded and bolted they may fare.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #6 of 46 Old 06-03-2011, 09:23 AM
Midnightluckey
I can't really see, but did you run a flat area under the grille to mount a winch?
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #7 of 46 Old 06-03-2011, 09:33 AM
speedbucket
i like it, i think on a lifted zj it would be more proportional
i wouldnt use those as recovery points
that bumper would be the perfect application for a forward hitch to be installed,
then you could
-have a reliable and safe recovery point
-hitch mounted winch that could be used front or rear
-very very easy way to park a boat or trailor
- and could put a little propeller on the front for a little added stability
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #8 of 46 Old 06-03-2011, 01:01 PM
zachk94
That looks good!!
zachk94 is offline
post #9 of 46 Old 06-03-2011, 01:34 PM
Midnightluckey
X2!! Get some bigger tires and springs under that beast and the bumper would look way more at home.
post #10 of 46 Old 06-03-2011, 02:20 PM
gothchick
Very nice indeed. Are you planning to add a winch bracket?
gothchick is offline
post #11 of 46 Old 06-06-2011, 10:00 PM
phbrown
1994 ZJ
RM,
why do you say not to use those rings?
Is it because of the type of weld?
I know nothing about welding so if you have the time please explain it in simple terms.
1994 Jeep Grand Cherokee Laredo| stock| 231 transfer case| 4.0L
phbrown is offline
post #12 of 46 Old 06-06-2011, 10:00 PM
phbrown
1994 ZJ
forgot to ask one more question
if someone wanted to do something like this where you weld the rings to the bumper what would be the best way to do it?
phbrown is offline
post #13 of 46 Old 06-06-2011, 10:07 PM
TallyZJ
You need at least 3/4" thick steel tabs coming through the bumper that are properly welded to the brackets that are very securely anchored to the frame rail. These tabs go way back and have a lot of weld bead on them to keep them from pulling off.
Or you could get something like THESE and mount them from the inside of the bumper through a small cutout.
Then you need actual RECOVERY SHACKLES, not those silly door knockers you have there.
Welding those cheap thin metal d-rings to the face of the bumper steel is not enough for recovery. They will break off or pull the sheet steel with it and create a missile of death.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #14 of 46 Old 06-06-2011, 10:19 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
RM,
Not often I agree with tally, this is one of those times. He pretty much nailed it.
It should be a piece of 3/4 or 1" stock run through the bumper and incorporated into the mount system so the load goes directly to the frame instead of the bumper. It would be welded front and rear to the plate. If you used box it would go all the way through. And should be welded 4-6" deep along the bumper mount tabs.
post #15 of 46 Old 06-06-2011, 10:40 PM
speedbucket
2 times i have seen recovery points fail in a bad way
one shackle went through a trucks window and out the winshield with strap in tow
another one happened 2 summers ago clearing trails at a hunt club, d ring took that hat and some scalp off of a 15 year old kid's head. inch lower and he would probably be dead.
they both happened with snatch snaps
ive also seen a chain break and imbed itself in a trucks tailgate
IMO bumpers should always be built around the recovery point, not build the bumper and then add the tow points.
bumper , iron , steel , zj
custom bumper pics GrandJC78 ZJ Grand Cherokee Forum 30 12-02-2008 10:26 PM
Zj bumper custom mounting underpowered ZJ Grand Cherokee Forum 2 10-15-2008 11:01 PM
custom bumper.. slick2570 ZJ Grand Cherokee Forum 4 09-25-2006 09:24 AM
Custom Bumper Slamm36 ZJ Grand Cherokee Forum 11 03-14-2006 03:37 PM
custom bumper ZJ_Jeep ZJ Grand Cherokee Forum 1 06-16-2005 03:04 PM
