ZJ exterior door panel clips. What are these called? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ZJ exterior door panel clips. What are these called?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Billet LED Tail LightsWant to be able to SEE? DOT Approved Headlights for under
Unread 11-30-2014, 07:41 PM   #1
ikidd
Trying to find some of these but I have no idea what to search under. They're the white clips that mount on the outside of the door and the plastic lower body trims clip on to.
Anyone have a part number? All I can find is the clips for snapping the interior trim on to the door. It's for a 98 Ltd 5.9 if that makes any difference.
TIA
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 08:01 PM   #2
Oldfrog
We call them : &*$$##$#@$#$#@@#!$%^&%&^!!(**%$%^^% !!!
Get them at a junk yard. Body clad retainers, I think.
Cajun Recipes and Fishing tips
Words of wisdom, Posted by Zeejay:
"..it's not air, it is the opposite of air... suckage so to speak."
Stalling? Work through Zeejay's list
Oldfrog is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 08:14 PM   #3
Uniblurb
Uniblurb's Avatar
Quite a few different ones depending on which part of the cladding you're installing. The OE numbers are on the right.
http://www.moparpartsoverstock.com/s...roduct=6846829
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is online now   Reply With Quote Quick reply to this message
Unread 12-01-2014, 05:25 AM   #4
coralman
I can wish can't I?
coralman's Avatar
There is a thread
http://www.jeepforum.com/forum/f13/h...-pics-1356774/
http://www.jeepforum.com/forum/f13/h...w-pics-915501/
which might help you.
Links to axle rebuilds, mount replace,a/c box rebuild,ect in history section of my profile page
coralman is offline   Reply With Quote Quick reply to this message
Unread 12-01-2014, 11:16 AM   #5
ikidd
That's great, thanks! Now I know what they're called
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
