ZJ Extended rear bump stops?? - JeepForum.com
 1Likes
  • 1 Post By Cody1
post #1 of 14 Old 11-15-2010, 11:30 PM Thread Starter
Cody1
I have 4.5 inches of lift on my zj i want some extended rear bumpstops!
Does anyone know where to find them? i have 2inch extentions with te stock ones but that isn't good enough to keep my back tires out of the fenderwells!
any info would be great
__________________________________________________ ______________________________
Rusty's long arms, RE 4.5 F+R inch coils, Rusty's HD front track bar, JKS rear track bar
Rusty's shocks, Drop pitman, 265/75R16 BFGoodrich AT's, Ultra wheels, rear sway bar deleted,
Cody1 is offline
post #2 of 14 Old 11-16-2010, 05:50 AM
Technohead
Make some for the rear from 1 1/2" x 3" tubing. See my build thread for pictures.
-Eric
Technohead is offline
post #3 of 14 Old 11-27-2010, 03:09 PM Thread Starter
Cody1
but is there any where that i could buy some?
AnotherRedZj likes this.
Cody1 is offline
post #4 of 14 Old 11-28-2010, 12:27 AM
tonymartin
What you can do is buy the RE 2" bump stop extensions (they are essentially pucks that go inside the coil on the lower perch) then fix some normal front bumpstops to the rear spring post.
tonymartin is offline
post #5 of 14 Old 11-28-2010, 08:11 AM
98BlackZJ
The puck style bumpstops are for the front. RE also has extented rear bumpstops that is basically a bracket that lowers the whole thing. Daystar also has poly extented rear bumpstops.
98' 5.2 ltd, 4.5" lift, 33x12.50 KM2's, Clayton's longarms, 8.8/HP30 Aussie F&R
98BlackZJ is offline
post #6 of 14 Old 11-28-2010, 09:12 AM
tonymartin
I know that, but the bracket is only 1.5" so he could put a front stock bump stop along with the puck to get around 4" of bump stop and remove the stock rear bump stop.
post #7 of 14 Old 11-28-2010, 12:04 PM Thread Starter
Cody1
I have the bracket that lowers the stock one 2inches.... i didnt know that daystar makes a poly version...I'm going to get a set of those and that should be good right??
thanks for all the help
Cody1 is offline
post #8 of 14 Old 11-28-2010, 04:05 PM
Technohead
Dude, just copy the RE drop but instead of 2" use 3" or 4" tubing. We are talking a couple dollars worth of steel and 4 bolts. You will spend at least ten times that to buy something else that you will probably still need to adapt in order to make work.
-Eric
post #9 of 14 Old 09-09-2012, 03:31 PM
Myusername1674
So reviving an old thread here, but I need to extend my rear bumpstops 2 inches, I've thought about two ways to do it.
The way i want to do it is by a square steel tube that is 2 inches wide, cut to size and just use as a spacer between the old stop and the unibody. My only problem is I can't find anyone around here who sells 2 inch square tubing. So my options are:
1. buy the 1 inch tubing they have at Lowes and Home Depot and use two peices of metal with longer bolts.
2. Use the spare hickory that we have (VERY tough wood) and cut it to size, bedline it (so it won't deteriorate), and use it as a spacer.
3. Cough up $30 and buy RE extended rears.
Keep in mind I'm in highschool working and my budget is low, plus i have many other repairs i need to do.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #10 of 14 Old 09-10-2012, 05:29 PM
Technohead
Check some area scrap metal yards. Or you can order small quanties online from a place such at www.metalsdepot.com.
-Eric
post #11 of 14 Old 09-10-2012, 11:36 PM
Cameleer
Stop by a weld shop and see if they have some laying around, or go to a place that sells metal. Itís really not that hard to find!
And yes, I did have to turn that bolt around.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #12 of 14 Old 09-11-2012, 07:02 AM
SKorch630
I have about a million feet of 2" square tubing in my shop. Steel of course. If its a small enough amount and you cover some shipping, i figure i can cut what u need and ship it out to you no problem. Its just your basic steel. Uncoated stock. So it'll be up to you to coat it so it doesnt rust! Let me know.
SKorch630 is offline
post #13 of 14 Old 09-13-2012, 09:50 PM
Myusername1674
That would be great! It's weird I'm having so much trouble finding it around here, there's probably someplace down in GA (more redneck than my city) but I don't go down there often enough to know.
I'll pm you about it if you still can
(in progress)
post #14 of 14 Old 01-28-2014, 06:03 AM
96zjlaredo
Just go to hickory farms and buy (2) of there SAUSAGES and cut them to length, They should work great. Then you can slice the cheese with a chainsaw and wax your jeep with it.
If a tree falls in the woods then farts, Do the other trees smell it?
96zjlaredo is offline
bump stops and rear swaybar? DrGrebo ZJ Grand Cherokee Forum 6 03-01-2010 09:12 PM
Extended bump stops for 6.5"? jopolly3 ZJ Grand Cherokee Forum 3 10-30-2008 07:41 PM
Extended Bump Stops and Adj Control Arms PSYCH0 ZJ Grand Cherokee Forum 17 09-16-2007 08:44 PM
Rear bump stops ZJenvy ZJ Grand Cherokee Forum 27 08-15-2007 05:45 PM
Bump Stops ? ssimpson6 ZJ Grand Cherokee Forum 5 04-03-2003 02:00 PM
