ZJ Engine Refreshment - JeepForum.com
post #1 of 29 Old 11-14-2013, 07:57 AM Thread Starter
ashland82391
Here's my clean 1995 GC limited 4.0 2wd with 270,000 miles.
In about a month I'm driving her from Michigan to Arizona while flat towing my YJ most of the way. I'll be the first to admit that's a pretty tall order for the 4.0 so I'm going to increase the odds of a successful trip.
First step was to test the compression. No point in putting money into a bad engine.
Considering how many miles, the engine tested pretty good.
Dry 110 100 100 95 100 100
Wet 140 120 125 125 140 140
I think cylinders 2,3,4 tested lower because of the head gasket leak.
The zj is in great condition all around with only a few concerns.
Tasks
Replace Head gasket
Replace Oil pump
While doing that I plan on replacing t stat, valve cover gasket, manifold gasket, injector o rings, and clean the rear diff. Everything else, plugs, wires, cap, rotor, water pump, trans, are all new or in good shape.
On to the fun! Tore everything apart. Head studs where kind of rusty so I let them sit in PB for a few hours. Last thing I need is for bolt to break of in the block.
After a few hours, head bolts came out fine :-)
ashland82391 is offline
post #2 of 29 Old 11-14-2013, 08:01 AM Thread Starter
ashland82391
Just took the head to get cleaned and milled. Should be done on Monday :-)
post #3 of 29 Old 11-14-2013, 08:10 AM
WJ4x4LIFE
A couple of questions out the gate.
1.) What did you pay for it?
2.) Why a 4.0L, not a V8? two-part question, was is a kinda of first come first serve (with known HG issue) or a preference?
3.) Why a 2wd model, again preference or reason?
Sorry, to bomb you with ?'s, but I like some context background to enjoy the story and build! I wish you the best of luck in your trip!
WJ4x4LIFE is offline
post #4 of 29 Old 11-14-2013, 08:14 AM Thread Starter
ashland82391
It's not a new to me Jeep. I've had it for around 4 years and had been in the family it's whole life spending most of it in California and Arizona. I received it for free so I didn't complain about it not bring 4wd. Plus, the YJ is more enjoyable offroading.
post #5 of 29 Old 11-14-2013, 09:07 AM
xcaliber81
How did you do the compression test? I did one but after I was told I did it wrong.
xcaliber81 is offline
post #6 of 29 Old 11-14-2013, 09:19 AM Thread Starter
ashland82391
It pretty simple.
1.Disconnect ignition
2.Remove spark plugs one at a time whole testing each cylinder with the compression gage
3.Screw gage inlet into the spark plug port.
4.turn the engine over a few times. The gage should make 4-6 big jumps and then slow down dramatically. Stop when this happens. This will be you dry test number.
5.Then remove gage and poor in a small amount of oil into the cylinder. Just enough to coat the cylinder head.
6.Repeat step four on the same cylinder. This well be your wet test.
7. Do this to all 6 cylinders resulting in 12 numbers. All dry numbers should be similar and all wet numbers should be similar.
post #7 of 29 Old 11-14-2013, 09:21 AM Thread Starter
ashland82391
It pretty simple.
Here's a good video that will better help you.
https://www.youtube.com/watch?v=X_tb...e_gdata_player
post #8 of 29 Old 11-14-2013, 09:27 AM
xcaliber81
i did not remove my spark plugs nor did i disable the ignition which resulted in 60 psi per cylinder. I also did that when i first bought it and i doubt my jeep has a 60 psi per cylinder engine lol.
post #9 of 29 Old 11-14-2013, 09:32 AM Thread Starter
ashland82391
?? How in the world did you test it with the spark plug in lol. Yeah, 60 is a pretty much shot engine.
post #10 of 29 Old 11-14-2013, 09:36 AM
xcaliber81
took out 1 plug at a time and started the engine ran for 5 or so seconds. everywhere else i have been reading said to remove all plugs and wires disable the fuel and ignition and crank for 5 seconds, so pretty much what you said.
post #11 of 29 Old 11-14-2013, 09:44 AM Thread Starter
ashland82391
Yeah, your not suppose to actually start the vehicle lol. Ya live a ya learn. You don't have to remove all the plugs at once though. Just pop off the write off the end of the plug then remove the plug and remove the center wire from the distributer cap. It connect to the the ignition.
post #12 of 29 Old 11-14-2013, 01:40 PM
JohnCrabtree
1994 ZJ
You're actually supposed to remove all plugs at once. If you have a leak in between cylinders and you crank it, your engine will pressurize both cylinders and read as pressurized. If you take all plugs out and have a leak between 2 cylinders then it will not hold pressure at all.
You can get a false positive by leaving plugs in. In other words, it can read good when it's bad.
JohnCrabtree is offline
post #13 of 29 Old 11-15-2013, 03:20 AM Thread Starter
ashland82391
Pulled the oil pan. Way more difficult on a stock vehicle as oppose to a lifted one lol.
Oil oil pump vs new
I also decided to do the rear main while I'm in there. I've heard how hard it is and how big a pain it it's to change but seriously it was cake...
post #14 of 29 Old 11-15-2013, 09:43 AM
xcaliber81
its only a PITA if you tear it a bit and have to do it all over again.
post #15 of 29 Old 11-15-2013, 11:21 AM
WJ4x4LIFE
Can't beat "FREE/given! "
