ZJ Electric Antenna Mast Replacement - JeepForum.com
post #1 of 12 Old 11-11-2008, 08:46 AM Thread Starter
Tyrefryer
I've had a search for this but haven't bveen able to find anything. My (1997 ZJ) antenna is broken off and I've order a new replacement mast. I can hear the antenna motor running when I turn the radio on. Can anyone tell me what's involved in replacing the mast/how I go about it?
Thanks.
Tyrefryer is offline
post #2 of 12 Old 11-11-2008, 09:22 AM
Mickey_D
According to the FSM the power antenna assembly is one unit. From what I can read there is no replacement mast. If there is, there's no instructions in the FSM on how to do it.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 12 Old 11-11-2008, 09:41 AM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Thanks.
I replaced the mast on my '94 years ago. IIRC, You have to remove the chrome mounting nut on the fender, then turn the radio on. The plastic toothed "ribbon" will come out thru the hole. You then put the new "ribbon" into the hole (the gear teeth must be facing the proper way) & turn the radio off. The ribbon is drawn in. Replace the nut & that's it.
Check out this eBay item # as an example: 370107423377
BTW: I have no knowledge of this seller, just posting this for your info.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 12 Old 11-11-2008, 10:17 AM
MAUSS
I replaced the mast on my '93 Limited a few years ago too. As SZJ said, it's fairly simple. I wish I'd had the correct wrench for the chrome nut though... I used electrical tape and water pump pliers to get it off and scarred it up a bit.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #5 of 12 Old 11-12-2008, 10:28 AM Thread Starter
Tyrefryer
Thanks for that.
post #6 of 12 Old 11-12-2008, 11:06 AM
CLNinja
CLNinja's Avatar
ive had a replacement mast sitting in my garage for 2 years... ive been too lazy to put it on... i never listen to the radio so it doesnt bother me
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #7 of 12 Old 11-12-2008, 02:44 PM
BloodRed
Well now that I know this isn't difficult, it is now on my project list. Mine is half bent and doesn't go down all the way.
BloodRed is offline
post #8 of 12 Old 11-12-2008, 05:16 PM
elmer_fud
Not hard as long as you can remove the old one. If I remember right pepboys had one that fit in a 93 if you put a 1/4 in spacer under it
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #9 of 12 Old 11-22-2008, 05:16 AM Thread Starter
Tyrefryer
I just got a new Mopar antennae but the last one they sent me didn't push the mast all the way up, it looked like it was too short. So I wanted to check the new one is the right one before I fit it. The part no. is 1 - 04773086AB, anyone know anywhere I can check part numbers?
post #10 of 12 Old 08-21-2013, 08:42 AM
matt5tt
Just fitted replacement aerial to my 1998 jeep zj. The mounting nut undoes easily - put a flat headed screwdriver in one of the grooves and tap with a hammer. The plastic teeth on the aerial "ribbon" need to face towards the front of the car when you feed it into the hole before turning the radio off. Bought my replacement from car-masts-uk on ebay, item number 400536154742 for £20. According to this ebay seller the Chrysler Jeep part number their aerial replaces is 4773086.
The ribbon on my old original aerial was shorter than the new one & I made the mistake of shortening the new ribbon to match. When installed it didn't catch properly to retract. On replacement aerial number 2(!) I did not make this mistake and installed as it came and it works perfectly.
Hope this helps someone.
matt5tt is offline
post #11 of 12 Old 08-21-2013, 11:10 PM
bjorn17
Has anyone replaced the electric antenna with a fixed regular one? I am having a hard time finding a proper one that fits on the angled edge of the fender good.
bjorn17 is offline
post #12 of 12 Old 08-22-2013, 04:20 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Don't know if this will help you but the base part number is 56007173. You may wind up replacing the body and cable assy as well but not sure on that. Part number for that is 56007373.
Originally Posted by HighLonesome
coralman is offline
Need solid mast antenna Baldman902 ZJ Grand Cherokee Forum 4 12-10-2009 03:03 PM
cant get antenna mast to pull in a70eliminator ZJ Grand Cherokee Forum 21 02-06-2008 03:19 PM
antenna mast replacecment alivenkickin28 ZJ Grand Cherokee Forum 5 02-14-2007 08:38 PM
Antenna replacement!? 02Lightning ZJ Grand Cherokee Forum 4 12-29-2006 10:20 AM
Replacement power antenna mast? MAUSS ZJ Grand Cherokee Forum 19 11-16-2005 07:34 PM
