ZJ Drive Train Help Please - JeepForum.com
post #1 of 13 Old 11-16-2012, 10:58 AM Thread Starter
jt_armstrong
1994 ZJ
I bought my '94 ZJ on Monday and took today off work to give it a general once over. After jacking up the front, I noticed both front wheels spin Despite this being my 5th Jeep it is my first with "always on" 4 wheel drive.
A quick check showed that the front drive shaft was missing. I also have a receipt from Jan '12 for the fitting of a new front diff. I am assuming both are linked. My questions:-
1)How does the Jeep manage the 4x4 function? Is it with a viscous coupling similar to the P38 Range Rovers?
2) How can I test the transfer box with a front drive shaft missing?
3) What damage will be caused if I continue to run it with only the rear wheels driving?
4) I also noticed that both front CV rubber boots are split. Is there a way to test the CV?
jt_armstrong is offline
post #2 of 13 Old 11-16-2012, 11:57 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
1 yes
2 can't
3 no more damage as its all been done. The coupler is already ruined by driving even a short time with no shaft.
4 replace the axle shafts
Before putting a new drive shaft in, verify the front gear ratio matches the rear.
ratmonkey is offline
post #3 of 13 Old 11-16-2012, 12:42 PM Thread Starter
jt_armstrong
1994 ZJ
Originally Posted by ratmonkey View Post
1 yes
2 can't
Thanks ratmonkey. Is there a recommended manufacturer for the replacment axle shafts?
post #4 of 13 Old 11-16-2012, 11:21 PM Thread Starter
jt_armstrong
1994 ZJ
OK, so I spent the afternoon wrestling with the hub nuts. What a PITA. Nothing i have will shift these wee rascals. I have a 2 foot breaker bar and even with all my 220lbs standing on the end of the bar it still wont budge. What else can i do? Will a manual impact driver help or do i just need to find a bigger breaker bar?
post #5 of 13 Old 11-16-2012, 11:30 PM
nicklopic
Soak it in PB blaster over night and try it again In the morning
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #6 of 13 Old 11-17-2012, 12:13 AM Thread Starter
jt_armstrong
1994 ZJ
Done. Fingers crossed tomorrow will bring more sucess.
post #7 of 13 Old 11-17-2012, 01:43 AM
Gr8Hondo
Brace your breaker bar on a jack and use the jack to do the back breaking job!
Gr8Hondo is offline
post #8 of 13 Old 11-17-2012, 04:43 AM
nicklopic
Goodluck man!
98' ZJ 4.0
post #9 of 13 Old 11-17-2012, 12:40 PM Thread Starter
jt_armstrong
1994 ZJ
Tried this heard the loud crack and thought success - unfortunetly it was my breaker bar that made the crack as the end shered off.
I think its time to throw in the towel and get a local garage to do this.
post #10 of 13 Old 11-17-2012, 12:52 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
usually any impact method will take it off pretty easily.
post #11 of 13 Old 11-17-2012, 01:30 PM Thread Starter
jt_armstrong
1994 ZJ
Would one of those manual impact drivers work? Lisle do one that claims to deliver 200 foot/lbs of shock torque. Amazon have it on offer for $30.
One last thing - just for sh1ts and giggles - tell me hub nut isnt a left hand thread.....
post #12 of 13 Old 11-17-2012, 02:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's standard thread.
they get seized pretty good. first one i ever did i needed to get it cherry red hot before it broke loose with a good 1/2" drive impact gun.
i was thinking get a good breaker bar and a decent 3lb brass hammer for the manual impact actually. lol
post #13 of 13 Old 11-21-2012, 08:55 PM Thread Starter
jt_armstrong
1994 ZJ
Success at last. Borrowed a mates battery powered impact driver and it whipped the nut off like it wasnt torqued up. I think i will be investing in one of these on black friday..Thanks for all your help and suggestions.
