ZJ door wiring harness fix write up - JeepForum.com
post #1 of 1 Old 02-23-2008, 01:36 PM Thread Starter
driabyor
driabyor's Avatar
1994 ZJ
REAR WINDOWS NOT WORKING.This is from my first repair.. The butt connector obviliously not the correct solution. I had previously cut the rubber boot off long ways... CUT THE BOOT FROM THE BOTTOM SIDE. Save the rubber boot. The boot is clipped to the door, but I can't remember how I removed it .It may just have 4 tabs that need lifted up. The boot is just press fit at the body , Pulls out rather easily
Next step was to test the function of the windows with a jumper wire.. They worked fine..
I stripped the wire about 1/4" . Tinned the ends with solder . Cut about a 6" jumper wire and coiled into a loop, Tinned the ends with solder. Then place 2 pieces of heat shrink on the jumper wire. Clamp together with alligator clips the apply heat and solder to the joints, remove clips. keep the joints as small as posssible to allow for more flexability..slide heat shrink over solder joints, shrink with solder iron. Sorry I forgot to take pics of this step.
Here is a kink I added about soldering
http://www.teamnovak.com/tech_info/h...der/index.html
Next apply some liquid tape to the other broken wires. It's messy but it may stop it from shorting. I did notice that I missed a couple of spots. I will fix them later.
Next use a couple of small nylon wire ties to bundle it together. Just snug but not tight, you want the wires to move. Clip excess tie ends off.
Next put the rubber boot back on,,, make sure you get back into the opening at the body to protect the wires from rubbing on the metal. I then put a couple of nylon wire ties around the boot. Clip the ends of the ties. I didn't bother with trying to put the boot back in the clip on the door.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
WJ Door wiring harness clip 3fifty ZJ Grand Cherokee Forum 2 08-17-2014 11:27 AM
Door Wiring Harness wires break leblancr ZJ Grand Cherokee Forum 18 03-18-2013 08:33 PM
Door Wiring Harness Peacemaker526 ZJ Grand Cherokee Forum 10 06-27-2009 01:42 PM
Wiring harness question ... 98 harness in 93?? mjessop23 ZJ Grand Cherokee Forum 1 05-24-2007 09:17 AM
Door Wiring Harness 4weeln ZJ Grand Cherokee Forum 3 03-24-2005 10:56 AM
