Zj died, won't start. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Zj died, won't start.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-22-2013, 07:22 PM   #31
ZeeJay1997
Originally Posted by AnotherRedZj View Post
Found a blown fuse.
i'm not bashing, but do yourself a favor and spend some quality time with your meter and learn how to use it. if you're gonna own a ZJ and do your own wrenching, it's a necessity. you can check all the fuses in the PDC in about 30 seconds. a barely blown fuse (if there is such a thing) cant hide from a voltage drop check.
The wire that was shorted on the same circuit that powers the injectors and coil, the output from the ASD relay.
it appears you need a new connector also. Being the rear sensor wiring, you can wrap it up with tape and stow it. you'll get a CEL but it doesnt affect the driveability. if you need an inspection, you'll need to fix it.
ZeeJay1997 is online now   Reply With Quote Quick reply to this message
Unread 10-23-2013, 07:01 AM   #32
AnotherRedZj
Luckily no inspection in FL. And I definitely will be looking for that connector.
As for the meter usage....sign me up for class. And thanks for your help Zee!
AnotherRedZj is offline   Reply With Quote Quick reply to this message
Unread 10-23-2013, 07:07 PM   #33
ZeeJay1997
plenty of youtubes on the subject, and Fluke has some good automotive articles to read. once you get the hang of it, it's like riding a bicycle.
