Zj died, won't start. - Page 3 - JeepForum.com
post #31 of 33 Old 10-22-2013, 06:22 PM
ZeeJay1997
Originally Posted by AnotherRedZj View Post
Found a blown fuse.
i'm not bashing, but do yourself a favor and spend some quality time with your meter and learn how to use it. if you're gonna own a ZJ and do your own wrenching, it's a necessity. you can check all the fuses in the PDC in about 30 seconds. a barely blown fuse (if there is such a thing) cant hide from a voltage drop check.
The wire that was shorted on the same circuit that powers the injectors and coil, the output from the ASD relay.
it appears you need a new connector also. Being the rear sensor wiring, you can wrap it up with tape and stow it. you'll get a CEL but it doesnt affect the driveability. if you need an inspection, you'll need to fix it.
ZeeJay1997 is offline
post #32 of 33 Old 10-23-2013, 06:01 AM Thread Starter
AnotherRedZj
Luckily no inspection in FL. And I definitely will be looking for that connector.
As for the meter usage....sign me up for class. And thanks for your help Zee!
AnotherRedZj is offline
post #33 of 33 Old 10-23-2013, 06:07 PM
ZeeJay1997
plenty of youtubes on the subject, and Fluke has some good automotive articles to read. once you get the hang of it, it's like riding a bicycle.
