zj died! - Page 2 - JeepForum.com
post #16 of 22 Old 01-06-2005, 05:26 PM Thread Starter
papashango
Originally Posted by jeepholic
Even if you don't go the swampy route, you can still cut a hole in the floor, if you don't mind and change it whenever it breaks in about 5 minutes, I have the trailer package and all that has to come off to get to the gastank, my rear floor is covered in rubber and it would never be seen.
cut a hole in the gas tank? can someone explain? i also found a good used fuel pump for $20...maybe something i have to go with (christmas and all kind of killed the ole wallet)...
papashango is offline
post #17 of 22 Old 01-06-2005, 05:31 PM
jeepholic
jeepholic's Avatar
Please raed the swamp linky! It's the first line, you cut a hole in the cargo area to access the fuel pump.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #18 of 22 Old 01-07-2005, 02:20 PM Thread Starter
papashango
ok, guys, maybe a stupid question, but how do you lift the carpet up? i've got these brackets that i can only imagine are for luggage tie-downs that are above the carpet but stuck on to the body...how's this work? should i just cut through the carpet?
here's a pic to what i'm talking about:
http://www.cmontecillo.com/images/jeep/cut.jpg
am i even looking in the right spot? thanks again, all!
post #19 of 22 Old 01-07-2005, 03:19 PM
greasefingers
greasefingers's Avatar
1994 ZJ
You got more difficult problems after removing the carpet...like how to safely cut a 8 to 10 diameter hole in the cargo bed !!
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #20 of 22 Old 01-07-2005, 03:40 PM
jeepholic
jeepholic's Avatar
Easiest way is to loosen the bolts that hold the tank, 2 in the back this will drop the tank enough to clear an accidental slippage with a drill, tank should be empty and you should try to not smoke as much as normally.
Cargo rails? I wasn't supposed to pull those out, sorry I removed mine when I put a rubber floor in.
I use a Jeep
You drive a car
Big difference.
post #21 of 22 Old 01-07-2005, 03:52 PM
jeepholic
jeepholic's Avatar
Before you go cutting a Jeep, understand my ZJ is a utility vehicle, it is made for work.
I fill the back with tools and parts, my dogs are always back there, it has a tent and chairs mounted behind the spare, it has 4 MRE's under the seat, I carry 5 gallons of water and 2 empty 5 gal jerry's. I backed it into a dumptruck and laughed, some one locked up the brakes and hit me pretty hard in the rear, I didn't even lower the radio, I just smiled and waved at her and drove home. I squeezed it through Bonnaroo traffic twice with 12 people hanging on the sides, my point is I don't count scratches, I use the truck and hope to keep it for awhile, so for me it's nothing to cut a hole in the back, even if I have to drop the tank to do it, since next time it will be easier.
Those cargo rails had always annoyed me, they make it uncomfortable to sleep back there.
I use a Jeep
You drive a car
Big difference.
post #22 of 22 Old 01-07-2005, 05:18 PM Thread Starter
papashango
yeah, i don't mind getting those things out (or scratches or prettiness), but how do you get the damn things out? it's not a bolt/screw that holds it down, looks like it's just supposed to NOT come out!
everything just died xjhavens ZJ Grand Cherokee Forum 4 10-14-2009 02:14 AM
CD player died tomiko ZJ Grand Cherokee Forum 4 01-18-2009 12:47 PM
it just died????? rustycherokee18 ZJ Grand Cherokee Forum 7 02-04-2007 07:36 AM
Jeep Died :-( adgjqetuo ZJ Grand Cherokee Forum 6 09-05-2006 10:42 PM
My '02 GC Died This Morning - Help. KellyN ZJ Grand Cherokee Forum 15 01-24-2006 09:56 AM
