ZJ: DEAFENING bearing noise, but only on accel! help! - JeepForum.com
post #1 of 8 Old 04-01-2009, 08:05 AM Thread Starter
aaron7
Ok. This one has me stumped.
I have a noise coming from the front end that sounds kinda like a wheel bearing... but it isn't; as I replaced both.
On the highway the sound is literally deafening. I can't hear the engine, wind noise, or my passengers.
Here's the weird part... the sound is only when I'm on the gas or braking. If I coast... it's silent!
WHAT IS IT??? I can't take it much longer!!
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
post #2 of 8 Old 04-01-2009, 10:13 AM
Eldoradoman
Check the diff fluid level, front & rear, plus the transfer case.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline
post #3 of 8 Old 04-01-2009, 10:14 AM
chris_nm1
Do you have a vibe with the noise? If so it is the same problem many of us here are experiencing. I just rebuilt my front diff this past weekend and it still did not take care of the problem.
98' Grandcherokee Laredo 5.2L bored .30over.
Edelbrock Performer Plus Cam
Custom made cat back
3" Teraflex Lift
Terflex Quick Disconnects
31x10.5x15 BFG A/T KO
chris_nm1 is offline
post #4 of 8 Old 04-01-2009, 10:29 AM
tirus89
Sounds like the pinion bearing. I got the same deal, except the breaking part.
tirus89 is offline
post #5 of 8 Old 04-01-2009, 11:53 AM
eshew
Yeah when my pinion bearing went out it was loud as hell. I think I spent about $400 fixing it. If you have a U-pull it nearby you may want to look into swapping out for a used front axle, could be cheaper in the long run... or now might be a good time to regear since you basically are going through the cost of gear setup in the front.
eshew is offline
post #6 of 8 Old 04-01-2009, 12:47 PM Thread Starter
aaron7
Ok, that's what I thought.
Time to put the HP D30 in there I guess haha
89 MR2 MK1.5
74 CB360
83 Firebird
aaron7 is offline
post #7 of 8 Old 04-02-2009, 04:22 PM Thread Starter
aaron7
Took this pic today while removing my driveshaft.
Who can spot why my bearing failed? Anyone?
89 MR2 MK1.5
74 CB360
83 Firebird
aaron7 is offline
post #8 of 8 Old 04-02-2009, 04:26 PM
Virmagicus
Virmagicus's Avatar
Do we have to ?
Jeff
Virmagicus is offline
Bad wheel bearing or tire noise? adgjqetuo ZJ Grand Cherokee Forum 5 07-17-2009 08:00 PM
Wheel bearing noise? 97DCZJ ZJ Grand Cherokee Forum 8 06-17-2009 04:47 PM
Diff Gear or Bearing Noise??? bkloos ZJ Grand Cherokee Forum 6 07-11-2008 02:51 PM
TC bearing noise? 13BTOY ZJ Grand Cherokee Forum 10 01-27-2007 01:47 PM
New owner - rear axle/bearing noise stevelv ZJ Grand Cherokee Forum 9 12-21-2006 08:26 PM
