ZJ Dana 44 shot - JeepForum.com
post #1 of 11 Old 04-01-2008, 10:12 PM Thread Starter
dacecil
ZJ Dana 44 shot
I just purchased a 98 ZJ Laredo V-8. The rear end was making noise so I opened it up and it was spitting out chunks of clutch pack. I purchased a new center section and am going to install it.
It is a 3.73 Trac Loc. What is the secret to installing it and setting it up? I have heard much talk around town about how this is not a job for an amateur, but I would like some other opinions from here.
Thanks for you help.
Dale
dacecil is offline
post #2 of 11 Old 04-01-2008, 10:22 PM
jdubbs107
first off, that's bs, if you don't learn now, when will you learn right? there's nothing fun about paying someone else to do to your jeep what you could do yourself
jdubbs107 is offline
post #3 of 11 Old 04-01-2008, 10:24 PM Thread Starter
dacecil
I agree jdubbs, that's why I'm asking around here. So what are the closely held secrets to this task?
Thanks
dacecil is offline
post #4 of 11 Old 04-01-2008, 10:24 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
make shure you get the gear back lash tool, cuse if this is done wrong you will drive down the street and your gears will prety much blow up.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #5 of 11 Old 04-01-2008, 10:24 PM
Virmagicus
Virmagicus's Avatar
well then enlighten us with your wisdom differential master.
Jeff
Virmagicus is offline
post #6 of 11 Old 04-01-2008, 11:02 PM
CLNinja
CLNinja's Avatar
ok... im all for doing things yourself
i installed 2 different lifts on my jeep myself (2.25BB and UC springs...then later on a 4.5" RE )
i (not entirely myself, ok Jim and Josh did most of it...lol ) installed my TC and swapped the input shafts
anything else that needs done to the Jeep i do myself
but gears is something i will never touch.... i leave that to the professionals
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #7 of 11 Old 04-02-2008, 06:04 AM
Colorado 5.9
Colorado 5.9's Avatar
So you bought a whole new trac-lok? You didn't have to. All's you needed was a new cluch pack. Only about a $100 & you don't have to worry about setting anything up like gear pattern or back lash & stuff like that. The carrier still has to come out to change the cluch pack. You just throw it back in after changing the cluch pack & bolt everything back up.
If a shop does it it's a whole lot cheaper!
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #8 of 11 Old 04-02-2008, 08:31 AM
jdubbs107
well if that's the case, which sounds logical enough, i semi revoke my statement
post #9 of 11 Old 04-02-2008, 08:32 AM
BLACKzj52
the clutch packs are $43 from kolak
BLACKzj52 is offline
post #10 of 11 Old 04-02-2008, 09:12 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Even my bud who has done diffs before and was a mechanic in his younger day is paying to have his done on his Olds 442. He found a guy who is reasonable and does good work. It's a big bear of a job and he'd rather spend the time with his kids.
HighLonesome is offline
post #11 of 11 Old 04-02-2008, 10:15 AM
ajmorell
ajmorell's Avatar
Yeah gears/diff work are one thing where you really have to know what you're doing....one mistake and all the money you spent on the new parts is out the window and you gotta do it again-gears and diff work aren't nearly as forgiving as most of the other stuff you can do yourself.
ajmorell is offline
Just got back and AC shot crazymjb ZJ Grand Cherokee Forum 5 08-23-2009 10:17 AM
PCM Shot??? COLDFEAR ZJ Grand Cherokee Forum 5 04-15-2009 10:54 AM
My Radiator is shot...HELP!!! ZJeepwill ZJ Grand Cherokee Forum 7 05-15-2008 05:54 AM
gun shot? spife7980 ZJ Grand Cherokee Forum 21 01-23-2008 04:43 PM
Radio about shot? boxoffire ZJ Grand Cherokee Forum 5 09-11-2004 06:57 AM
