ZJ D35 to D44a swap whats needed - JeepForum.com
post #1 of 18 Old 07-27-2009, 05:20 PM Thread Starter
jeep95xj
1995 XJ Cherokee
My D35 is on its way out. I found a D44a out of a 98 ZJ and from what it looks like ill need the rear obviously and the driveshaft to do the swap. Am i missing anything? The 98 is a limited 5.2 my 96 is a leredo 4.0 If i go through with it ill swap the front 30 in also since i have 3.55 gears and the D44 has 3.73 gears.
jeep95xj is offline
post #2 of 18 Old 07-27-2009, 05:47 PM
blackjack12982
1994 ZJ
blackjack12982 is offline
post #3 of 18 Old 07-27-2009, 05:50 PM
Jones
Consider the following...
Jones's Avatar
You pretty much unbolt the old axle and swap the new one in. Make sure the gears are the same front and rear. If they aren't and you have the all time 4wd 249 TC you'll need to take off the front driveshaft till you have the same gears.
Jones is offline
post #4 of 18 Old 07-27-2009, 06:06 PM
squashman702
1994 ZJ
I just did 44a>44a on my 5.9 recently. Your brakes will swap over from your 35 to your 44a, so I would strongly suggest doing what you can to avoid having to bleed them. I left all of the lines attached still to avoid this. Just like anything else, hit everything with PB blaster as far as you can in advance as it will absolutley make your life easier. I would suggest changin your ebrake shoes as well as they are likely toast on the 44a and will be seized if it was sitting outside for any period of time.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #5 of 18 Old 07-27-2009, 07:16 PM Thread Starter
jeep95xj
1995 XJ Cherokee
I believe the driveshaft length is different on the 44A and the D35 am i right?
jeep95xj is offline
post #6 of 18 Old 07-27-2009, 07:27 PM Thread Starter
jeep95xj
1995 XJ Cherokee
blackjack12982 great write up in that link but the ZJ and WJ have a totally different rear end so it may not all be the same as far as problems and such are concerned.
jeep95xj is offline
post #7 of 18 Old 07-27-2009, 08:01 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Basic principal is the same...I don't know of anything (aside from suspension connections) that would be different.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #8 of 18 Old 07-27-2009, 08:16 PM Thread Starter
jeep95xj
1995 XJ Cherokee
OK so to do the swap id use the ZJ D44a rear with the matching driveshaft from that doner truck and im set. No need for a custom shaft or anything like that. Sound about right?
jeep95xj is offline
post #9 of 18 Old 07-27-2009, 08:19 PM
squashman702
1994 ZJ
Not sure if this would work due to the output of the 249 being different than the 242 . . . unless you already have the 249 in your Laredo.
Think Twice Garage
post #10 of 18 Old 07-27-2009, 08:23 PM Thread Starter
jeep95xj
1995 XJ Cherokee
No i have a 242. Can i swap the yokes on the driveshafts?
jeep95xj is offline
post #11 of 18 Old 07-27-2009, 08:25 PM
squashman702
1994 ZJ
I don't see why you couldn't aside from it could potentially be a PITA, and you might get vibrations from using parts from two different driveshafts. I could be wrong though.
Think Twice Garage
post #12 of 18 Old 07-27-2009, 08:28 PM Thread Starter
jeep95xj
1995 XJ Cherokee
Nothing is ever simple lol I dont think they balance the DS with the yoke on it. Simply replacing a u-joint ould throw that off if that was the case. However i may also be wrong.
jeep95xj is offline
post #13 of 18 Old 07-27-2009, 09:17 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
My experience:
http://www.jeepforum.com/forum/f13/d44a-swap-tips-569533/
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #14 of 18 Old 07-29-2009, 10:37 PM Thread Starter
jeep95xj
1995 XJ Cherokee
bump. anymore ideas?
jeep95xj is offline
post #15 of 18 Old 07-30-2009, 02:18 AM
zjgray
if the front dana 30 out of the doner is good then you don't even have to bother doing the ring and pinyin swap could make things a lot easier
zjgray is offline
Swap D35 with D44a WhiteOut ZJ Grand Cherokee Forum 16 03-10-2010 10:34 PM
If I Swap to a d44a what about the d30 in front? outlaw8383 ZJ Grand Cherokee Forum 11 01-29-2010 12:32 PM
D44a swap ? bigjeep6303 ZJ Grand Cherokee Forum 5 12-19-2009 01:16 AM
D44a swap into my 93 with drums... ? aaron7 ZJ Grand Cherokee Forum 8 07-01-2009 06:00 PM
ZJ swap D44a brakes for a D35 BradMB2004 ZJ Grand Cherokee Forum 5 07-04-2007 05:56 PM
