ZJ - Check Gauges light and oil pressure goes down? - JeepForum.com
post #1 of 7 Old 09-15-2008, 10:46 PM Thread Starter
MoonyJohn
Ok, so maybe after 20 minutes of driving I come to a stop and my oil pressure gauge goes all the way down and then the Check gauges light comes on. But when i start moving again, the gauge goes back up to where it used to be. The pressure usually starts at 45ish but then goes down to 20 in 5 minutes.
Any solutions?
MoonyJohn is offline
post #2 of 7 Old 09-15-2008, 11:40 PM
dcvance87
Fuel pressure regulator is going out. Nothing to worry about. Mine does that occasionally.
06' TJ, 4" Rough Country lift, 2" body lift, 35 BFG all-terrains.
dcvance87 is offline
post #3 of 7 Old 09-15-2008, 11:43 PM
Ds4x4
Ds4x4's Avatar
Not necessarily, you can replace the sender located on the engine obviously as it is easiest. but you need to check into this don't just blow it off.. I know that on my 89 Chevy p/u i have the same issue, and i need a crank kit.. there could be more to it than that, start cheap and simple then work your way to other things..
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #4 of 7 Old 09-16-2008, 01:56 AM
vp6799
Mine did the same exact thing as yours is doing.
I just replaced the oil pressure sending unit and it fixed the problem. I read allot about those going out so I replaced it. Haven't had that problem since.
Here's a pic and a link to one at auto zone:
Oil Pressure SWitch
Vic
vp6799 is offline
post #5 of 7 Old 09-16-2008, 02:00 AM
NorCal_96_ZJ
I also used to have that problem...my problem was just a bad negative battery terminal wire plug/hook up.
NorCal_96_ZJ is offline
post #6 of 7 Old 09-16-2008, 08:37 AM Thread Starter
MoonyJohn
alright, thanks everyone. Ill try ordering one of those oil pressure switches sometime in the near future.
post #7 of 7 Old 09-16-2008, 06:48 PM
vp6799
I wouldn't wait too long to do it, because if that's not your problem then your gonna damage something else.
The oil pressure switch is just the cheapest start to find the problem. More than likely that is your problem, but if it's not and you wait too long. Your chancing a bigger repair.
Vic
vp6799 is offline
Oil Gauge won't come on/check gauges light. flinthills76 ZJ Grand Cherokee Forum 3 08-28-2009 07:36 PM
Check Gauges Light debbie9339 ZJ Grand Cherokee Forum 2 08-21-2007 02:32 PM
97 Jeep Grand - Temp running high, check gauges light flashes darkstarpa ZJ Grand Cherokee Forum 4 04-13-2007 09:33 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
check oil light, and low oil pressure the gauge... kujo666666 ZJ Grand Cherokee Forum 7 06-15-2006 05:11 AM
