ZJ bumpstops - JeepForum.com
post #1 of 8 Old 08-30-2011, 10:43 AM Thread Starter
Darman
ZJ bumpstops
i somehow lost one of my rear bump stops on my 95 v8 zj and sheared one of the bolts off the other side. can i buy any ZJ bumpstops to replaace them with or are they rear specific?
Darman is offline
post #2 of 8 Old 08-30-2011, 11:58 AM
KingtheZJ
many people run generic bumpstops in the rear because they are easy to find and modify. daystar, for one, make some good ones. search "leaf spring bumpstops"
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 8 Old 08-30-2011, 12:15 PM
Dyn0mitemat
Autozone sells energy brand bumpstips that replace them
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #4 of 8 Old 08-30-2011, 12:28 PM
melk
Are we talking coil posts or those rectangular things on the frame?
melk is offline
post #5 of 8 Old 08-30-2011, 01:07 PM
LordHobbit
rears are rectangular on the axle.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 8 Old 08-30-2011, 03:53 PM
Dyn0mitemat
My rears are on the unibody frame rails above the axle
post #7 of 8 Old 08-30-2011, 04:11 PM
KingtheZJ
he said rear, so i was assuming the rectangular ones that are on the frame rail and contact the axle tube at full bump
'88 XJ
post #8 of 8 Old 08-30-2011, 08:49 PM Thread Starter
Darman
the rectangular ones on the rear. sort of look like a hard foam material.
i need ones with the holes in the same place as i just installed my lift and need the holes to line up for the extended bump stop mounts
Darman is offline
bumpstops bigb229 ZJ Grand Cherokee Forum 8 07-07-2010 06:02 PM
ZJ rear bumpstops BradMB2004 ZJ Grand Cherokee Forum 7 02-27-2008 10:22 PM
rear bumpstops hckypro19ja ZJ Grand Cherokee Forum 4 04-21-2007 11:47 PM
Bumpstops offroader156 ZJ Grand Cherokee Forum 19 03-09-2007 04:08 PM
Bumpstops??? grovesj2 ZJ Grand Cherokee Forum 3 03-01-2005 12:51 AM
