zj build help - JeepForum.com
post #1 of 10 Old 04-12-2010, 12:41 PM Thread Starter
93ZJDave
zj build help
I just wanna take some advise or opinions about my jeep so far I have a custom 3 inch lift with 33x12.50x15 bfg mud terrains. Rear quarters are rolled I have pro comp es1000 hydro shocks upgraded front anti swaybar links I had a few people look at the number plate on my rear and people have told me its a dana 41??? I still need a few more things this pay I will be ordering a 4.5 rough country lift a 3000 pound winch a custom hand throttle and rock sliders if I can find em cheap.
93ZJDave is offline
post #2 of 10 Old 04-12-2010, 01:03 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Unless someone swapped axles on it, you have a D30 in the front and a D35 in the rear. The D44a didn't come along until 1996 and only if you have a V8 at that point. Every ZJ prior to that had the D35.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 10 Old 04-12-2010, 01:10 PM Thread Starter
93ZJDave
YEah I knew they. Had the dana 30 up front and 35 in the rear the dana 44 in the v8 grands were an aluminum housing with steel shafts but I'm not worried about my axles quite yet lol I need to make a hand throttle for mine to when I get the time
93ZJDave is offline
post #4 of 10 Old 04-12-2010, 01:19 PM
ArloGuthroJeep
Mr. Hyde!
Why are you looking at a 3000lb winch? That is grossly under rated for your Jeep...
post #5 of 10 Old 04-12-2010, 02:01 PM Thread Starter
93ZJDave
It wouldn't be used for anything crazy only thick mud if I get stuck I lost my 96 cherokee cuz it sat in a puddle to long and the motor went I don't want that happening again
93ZJDave is offline
post #6 of 10 Old 04-12-2010, 02:02 PM
kwellzz
def not enough power if using for thick mud
Denver Motorcycle Repair
kwellzz is offline
post #7 of 10 Old 04-12-2010, 02:06 PM Thread Starter
93ZJDave
well this zj is much biggers then my xj so I don't think it will get stuck
93ZJDave is offline
post #8 of 10 Old 04-12-2010, 02:11 PM
MurdaJs
If you arent going to get stuck, then theres no need for a winch
Everyone is going to tell you that 3k is def not enough for a zj, much less one fighting the suction of mud. Im looking at 8k as a minimum
MurdaJs is offline
post #9 of 10 Old 04-12-2010, 02:22 PM Thread Starter
93ZJDave
Indeed no need for a winch lol also do they make hand throttle kits
93ZJDave is offline
post #10 of 10 Old 04-12-2010, 02:47 PM Thread Starter
93ZJDave
Also my 4wd seems to act up it goes into 4wd but when I try low range it seems like it wont engage I think its a linkage problem
93ZJDave is offline
where to buy 4.7 re-build kit??? kik_start ZJ Grand Cherokee Forum 5 04-29-2008 08:16 AM
what do i need to build my own kit? super13jew ZJ Grand Cherokee Forum 5 04-13-2008 08:56 AM
help me build my ZJ Gunnison ZJ Grand Cherokee Forum 3 12-30-2006 02:38 PM
Build? devilfish ZJ Grand Cherokee Forum 13 09-15-2006 08:36 AM
THIS is how u build a ZJ! grandman97 ZJ Grand Cherokee Forum 32 08-31-2006 04:05 PM
