ZJ budget boost help!! - JeepForum.com
post #1 of 13 Old 05-07-2013, 10:20 PM Thread Starter
louie5505
Hello guys I am back with another question
I have a stock 4.0 i6 zj
I want to put a 2" budget boost on it.
I am hearing alot about the death wobble with a zj and budget boost.
What would I have to do to avoid getting a death wobble.?
louie5505 is offline
post #2 of 13 Old 05-07-2013, 10:26 PM
GCjunkie93
Make sure bushings, TRE's, etc. are good and tight. If you have problems after checking all that, then you have a serious problem because a BB won't the geometry of anything that drastically.
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline
post #3 of 13 Old 05-07-2013, 10:30 PM
tucsonzj
Many people don't upgrade other parts when they do a BB. Which is not required, but can make life easier, especially if you're going to wheel it. There's tons of info on here about DW. Do some searching around and you'll see the cause and fixes.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #4 of 13 Old 05-07-2013, 10:31 PM Thread Starter
louie5505
So if everything is tight. It shouldn't do a death wobble? Even with stock tires?
post #5 of 13 Old 05-07-2013, 10:44 PM
capcyclone
capcyclone's Avatar
Okay - what is TRE an acronym for?
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #6 of 13 Old 05-07-2013, 10:48 PM
GCjunkie93
The only reason you would get DW with a small amount of lift like that is worn out parts. Before you install, it would be a great time to check over your steering components.
post #7 of 13 Old 05-07-2013, 10:48 PM
GCjunkie93
tie rod end
post #8 of 13 Old 05-07-2013, 10:49 PM
MTBlue
Tie Rod End(s)
I had to google it too haha
Dirt Deprived
MTBlue is offline
post #9 of 13 Old 05-07-2013, 11:11 PM
dnuccio
^this
dont stop at just the steering components, check ALL front end bushings. control arms, track bar, etc
and a steering stabilizer will never cause death wobble, it just masks the real problem. with a perfectly set up front end, you wouldnt even need a steering stabilizer.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 13 Old 05-08-2013, 04:58 AM Thread Starter
louie5505
How can I tell if anything in the front end is bad enough to cause death wobble?
post #11 of 13 Old 05-08-2013, 08:16 AM
Myusername1674
One way, lay under the jeeps front end, have a buddy turn the wheel back and forth, look for play.
You could do what I did, (the lazy way). Do your 2inch bb, then if you get dw fix it then. My Jeep had 240k on it original suspension, I bb it, no dw, so now i go on being happy. This was several k's ago. I'm guessing your going to be fine.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #12 of 13 Old 05-08-2013, 08:31 AM Thread Starter
louie5505
You could do what I did, (the lazy way). Do your 2inch bb, then if you get dq fix it then. My Jeep had 240k on it original suspension, I bb it, no dw, so now i go on being happy. This way several k's ago. I'm guessing your going to be fine.
Thanks bud
post #13 of 13 Old 05-10-2013, 02:29 PM
BuzzZJ9er
I have heard when installing a lift or BB you should crack your CA bolts loose so the bushing isn't under added stress at a stand still. Can imagine this will increase bushing life and help reduce DW. This is what I have heard, I'm no ace mechanic though.
BuzzZJ9er is offline
