Zj brake upgrade? - JeepForum.com
post #1 of 13 Old 04-19-2014, 02:11 AM Thread Starter
Thomahawk
Zj brake upgrade?
Hi, what upgrades Are guys doing,
I feel lack of brsking power after going up to 31" tires, and have some akebono WJ calipers around,,,
Will they fit?
Will it be an upgrade?
What else do you guys recomend?
Buildthread
Thomahawk is offline
post #2 of 13 Old 04-19-2014, 05:16 AM
Timo_90xj
Timo_90xj's Avatar
WJ calipers need WJ knuckles and steering parts, and may need slight modifications to trackbar mount, hub-to-knukcle 1/4" spacer, some other small things. Look for "WJ knuckle swap", and you'll find polenty of info on this forum/ google.
WJ knuckle & brake swap including steering has been the single best mod onmy niner. There is a MAJOR difference in stopping power, and the WJ cross- over steering is also a big improvement over the ZJ/XJ/MJ/TJ inverted-y crap. Well worth the effort IMO. I spent total of about 700 on my swap, including remanufactured calipers & brackets, knuckles glass-bead cleaned & powder coated, new rotors & pads, new Moog TREs + custom draglink + trackbar. I built the steering OTK and built custom trackbar mount and used JKS DIY trackbar in the front. Running UTK it's a bit easier.
I've got some pictures on my niner build thread.
***Under construction***
Timo_90xj is offline
post #3 of 13 Old 04-19-2014, 09:43 AM
CatSplat
1994 ZJ
Some guys have left the steering UTK, so you don't have to relocate the track bar or sway bar links but your tie rod will hang lower.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #4 of 13 Old 04-19-2014, 09:54 AM
Hawkeye01
I upgraded mine to the EBC slotted and dimpled rotors front and back and went with the yellow stuff pads up front with the green stuff in the rear. It's like day and night difference from the stock brakes. It was easy to replace and no mods were needed.
Semper Paratus
Hawkeye01 is offline
post #5 of 13 Old 04-19-2014, 10:34 AM
riot1987
I was really curious as to how those EBC's worked. Youre pretty happy with them eh? For what you pay they better stop you!
OP Ive heard that later model Akenbono calipers are the way to go for the swap. Dual pistons up front is a hell of an upgrade over stock
Build thread^^
riot1987 is offline
post #6 of 13 Old 04-19-2014, 10:54 AM
Hawkeye01
Yes I'm very happy with them. I originally chose these because I used to tow my boat that weighed close to 4000lb including the trailer. I was a big upgrade from the stock and there was no mods that were needed.
Semper Paratus
post #7 of 13 Old 04-19-2014, 12:08 PM Thread Starter
Thomahawk
Originally Posted by Timo_90xj
WJ calipers need WJ knuckles and steering parts, and may need slight modifications to trackbar mount, hub-to-knukcle 1/4" spacer, some other small things. Look for "WJ knuckle swap", and you'll find polenty of info on this forum/ google. WJ knuckle & brake swap including steering has been the single best mod onmy niner. There is a MAJOR difference in stopping power, and the WJ cross- over steering is also a big improvement over the ZJ/XJ/MJ/TJ inverted-y crap. Well worth the effort IMO. I spent total of about 700€ on my swap, including remanufactured calipers & brackets, knuckles glass-bead cleaned & powder coated, new rotors & pads, new Moog TREs + custom draglink + trackbar. I built the steering OTK and built custom trackbar mount and used JKS DIY trackbar in the front. Running UTK it's a bit easier. I've got some pictures on my niner build thread.
Thx a ton Timo, excactly what i needed to know, its for my friend, i will Ask him how far he want to Go with this,,,
Great pic, highly apriciated, thx
I have great expirience with EBC shhhh, i use it on my bike
My WJ will have Stillen/Black matrix brakes soon.
Buildthread
post #8 of 13 Old 10-20-2014, 05:07 AM
danfau07
Need some more info. I want to do the upgrade to the wj brakes, but my diff is on its way out. Would i able just to swap out the axle to a wj and replace the caplipers?
97 Grand Cherokee Limited 4.0
5.5 Inch long arm lift (rustys Offroad)
danfau07 is offline
post #9 of 13 Old 10-20-2014, 05:16 AM
PolkaPower
Straight bolt in high quality custom brakes. No drilling or anything special. http://www.vancopbs.com/category_s/121.htm
PolkaPower is offline
post #10 of 13 Old 10-20-2014, 08:22 AM
CatSplat
1994 ZJ
No, the WJ front axle is wider and does not have the same control arm geometry as the ZJ axle. It also has a different wheel bolt pattern.
The Jeep of Theseus
CatSplat is offline
post #11 of 13 Old 10-20-2014, 08:33 AM
kg6mov
Hears the voices
kg6mov's Avatar
If you're lifted an HP30 would be a reasonable upgrade. Build it with WJ knuckles and swap it in.
kg6mov is online now
post #12 of 13 Old 10-20-2014, 09:31 AM
Matta94GCL
1994 ZJ
Yes! I plan to do this too, but only when my existing axle gives up.
Matta94GCL is offline
post #13 of 13 Old 10-20-2014, 04:17 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Polka, why do you put temptation in front of me?
Originally Posted by HighLonesome
coralman is offline
