ZJ brake caliper upgrades? - JeepForum.com
post #1 of 13 Old 01-27-2005, 12:15 AM Thread Starter
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
I've seen quite a few disc/rotor and pad upgrades from Stillen, Brembo and other manufacturers.
How about calipers? Are there any good caliper upgrade kits for a ZJ?
I'd prefer something that bolts in without much modification. However, even if you came up with a relatively straightforward way to adapt calipers from another make and model, I'd like to read about it.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline
post #2 of 13 Old 01-27-2005, 12:53 AM
CaliforniaJeep
CaliforniaJeep's Avatar
Check this out!
1.http://members.aol.com/xjguy/auto6/index.htm
2.http://www.cardomain.com/memberpage/26605/4
This guy as a 6 piston brake kit! The rotors look small but once I looked at the wheels size they are very big.
I have put 4 piston calipers on my to-do list. Company's such as Wilwood, and Outlaw brakes can make custom brake kits for your Grand Cherokee!
Hope that helps
-Johnny-
~Updating~
CaliforniaJeep is offline
post #3 of 13 Old 01-27-2005, 06:47 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Upgrading the brakes is what I consider to be one of smartest Mods one could do. Especially for those who increase their tire diameter. Our stock calipers have one piston, but the four piston calipers use two on each side, which means that they do not rely on the caliper housing to slide on those pins. This is a great improvement in design over 1 & 2 piston calipers. I would like to hear details from someone that has done this on a GC.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 13 Old 01-27-2005, 08:33 AM Thread Starter
josephmartins
Long-time Jeep Nut
Has anyone done a WJ to ZJ caliper swap?
Kind regards,
Joe Martins
Milford, NH
post #5 of 13 Old 01-27-2005, 11:07 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
So Grease,
What would you recommend for someone like me? Calipers, pads, rotors?
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #6 of 13 Old 01-27-2005, 11:18 AM
greasefingers
1994 ZJ
Sorry I am not an expert in this area. But whatever you do, get red calipers. They would look really hot
Cheers Steve
post #7 of 13 Old 01-27-2005, 11:54 AM
Phil Gerard
Former Mod
Great Minds Think Alike! Because I was thinkin the EXACT same thing!
RED CALIPERS
Phil
post #8 of 13 Old 01-27-2005, 12:32 PM Thread Starter
josephmartins
Long-time Jeep Nut
RED CALIPERS
Phil
A low-buck approach would be to degrease and sandblast your existing calipers and buy some of that caliper paint.
For under $50 you can have 4 red calipers...albeit not better ones, but they'll be red.
Kind regards,
Joe Martins
Milford, NH
post #9 of 13 Old 01-27-2005, 01:37 PM
Phil Gerard
Former Mod
And there I'll be, telling my insurance agent, " I really thought painting those calipers red was good for at least 10 feet....I just knew I was going to stop short of that tree...Oh well....my insurance is going up how much?... and you're totalling my ZJ and giving me how little?"
I think when and if I have red calipers they'll be the real thing bit you're right Joe if I had state of the art brakes and wanted red calipers I'd do what you said!
Phil
post #10 of 13 Old 01-27-2005, 02:05 PM
acrscotland
acrscotland's Avatar
I just had a look at the Outlaw 4000 calipers - for $165 a piece that seems like reasonable value if they'll work with stock rotors etc....particularly if it hauls you up quicker That's my only real complaint running the Jeep on a daily basis is that the brakes are not the best...but they work, at least! Mind you, I didn't realise that it was such a sin to change out the rotors and pads at the same time - that's what I did with my rear's. Is it really that much of an issue? I kind of had no choice, though since the backing on my pads was grinding the rotor... I won't be letting that happen again...!
Chris
1995 ZJ Limited 5.2L
Kolak 3" Exhaust w/ Flowmaster 70, Edelbrock IAS shocks, Addco Sway Bars Front & Rear, OME Steering Stabilizer, K&N drop-in, Hella 500 spots & Hella 550 fogs
acrscotland is offline
post #11 of 13 Old 01-27-2005, 02:16 PM Thread Starter
josephmartins
Long-time Jeep Nut
Where did you find them? I looked earlier and could not get through to the manufacturer's site - www.rebcoracing.com
Kind regards,
Joe Martins
Milford, NH
post #12 of 13 Old 01-27-2005, 02:24 PM
acrscotland
I saw them at Behrents and The Car Shop
I hope that helps....
Chris
post #13 of 13 Old 01-27-2005, 02:50 PM Thread Starter
josephmartins
Long-time Jeep Nut
Perfect, thank you.
I found out from Behrents that the information I found online earlier was incorrect. The manufacturer is www.outlawdiscbrakes.com 770-844-1777
I called the company. Extremely helpful people.
Bolt pattern of the 4000 Outlaw is two 5/16" bolts, 3.5" on center. Custom bracket fabrication would be required for a ZJ. They recommended talking to a machine shop rather than an automobile repair shop which makes sense.
Kind regards,
Joe Martins
Milford, NH
WJ brake caliper bolts foundryrat ZJ Grand Cherokee Forum 5 08-02-2015 01:54 AM
Brake Caliper Help!! joecalik ZJ Grand Cherokee Forum 3 09-04-2009 10:14 AM
ZJ Brake Help!! Caliper will not come off rotor DothanJeep ZJ Grand Cherokee Forum 5 08-13-2009 12:17 AM
brake caliper bolts JackStraw ZJ Grand Cherokee Forum 16 02-11-2009 01:07 PM
Brake Caliper Upgrades macdiesel ZJ Grand Cherokee Forum 2 05-09-2008 01:26 PM
