ZJ axle swap - JeepForum.com
post #1 of 8 Old 03-20-2014, 12:25 PM Thread Starter
puckett
ZJ axle swap
Will a front diff from a 94 Cherokee work under a 93 Grand Cherokee
puckett is offline
post #2 of 8 Old 03-20-2014, 12:35 PM
Zakimations
Http://csloffroad.com/jeepzjxjwjaxleinfo.aspx
Yes. It will.
I am currently in the middle of doing this very same swap.
Zakimations is offline
post #3 of 8 Old 03-20-2014, 12:54 PM Thread Starter
puckett
Is it a direct swap or is there some fabrication that needs to be done
puckett is offline
post #4 of 8 Old 03-20-2014, 12:56 PM
WhiteOut
WhiteOut's Avatar
Direct swap so long as the gear ratios are the same and the driveshaft type is the same.
WhiteOut is offline
post #5 of 8 Old 03-20-2014, 02:15 PM
Mark-318-IT
Yes. It will.
usefull link thanks
Mark-318-IT is offline
post #6 of 8 Old 03-20-2014, 03:51 PM
Technohead
Don't be surprised if the high pinion Cherokee axle has interference issues when swapped into an unlifted Grand Cherokee. Also note that the Grand Cherokee D30 uses cam bolts on the lower control arm mounts to adjust caster. The Cherokee D30 lower control arm brackets do not work with cam bolts.
-Eric
Technohead is offline
post #7 of 8 Old 03-20-2014, 04:13 PM Thread Starter
puckett
I thought 95 and newer were the high pinion? I have a four inch lift so if it is I don't think that clearance will be an issue.
puckett is offline
post #8 of 8 Old 03-20-2014, 06:34 PM
SAR-Swimmer
Do you mean 95+ ZJs were high pinion? If that's what you mean, no, the ZJs didn't come with high pinion, and that's why a lot of people swap them out.
SAR-Swimmer is offline
