zj awd trans problems - JeepForum.com
post #1 of 11 Old 10-29-2013, 02:45 AM Thread Starter
Rob84
95 zj awd wont go into 1st even if manual shifter help plz
Rob84 is offline
post #2 of 11 Old 10-29-2013, 04:59 AM
newfieZJ
Most likely a valve body issue . Partially open governor valve or sticky valve in general . Remove , clean , reassemble .
Welcome and PLEASE fill out your jeep profile !
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 11 Old 10-29-2013, 03:22 PM Thread Starter
Rob84
Thank you. Will give it a try. Will do on the profile.
Rob84 is offline
post #4 of 11 Old 10-30-2013, 04:58 PM Thread Starter
Rob84
How do I find out what transmission is in my jeep?
Rob84 is offline
post #5 of 11 Old 10-30-2013, 06:09 PM
newfieZJ
42re
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #6 of 11 Old 10-31-2013, 02:34 AM Thread Starter
Rob84
How do you know for sure?
Rob84 is offline
post #7 of 11 Old 10-31-2013, 02:44 AM
kensnelling
The 42RE was the only transmission installed behind a 4.0L in '95.
Ken
kensnelling is offline
post #8 of 11 Old 10-31-2013, 04:22 AM Thread Starter
Rob84
Cool thnx
Rob84 is offline
post #9 of 11 Old 11-15-2013, 06:44 AM Thread Starter
Rob84
Should I replace the pressure sensor along with the shift silonoid?
Rob84 is offline
post #10 of 11 Old 11-15-2013, 09:57 AM
xcaliber81
The awd is the tcase not the trans.
xcaliber81 is online now
post #11 of 11 Old 11-17-2013, 09:27 PM
breeaad
How do you know its a shift solenoid? The PCM will put the trans into limp mode and it will not go into 1st if it detects something wrong. My GC went into limp and stayed in 2nd gear when my speed sensor went bad. Have you pulled codes?
breeaad is offline
