-   -   zj awd trans problems (http://www.jeepforum.com/forum/f13/zj-awd-trans-problems-1734850/)
Rob84 10-29-2013 02:45 AM
95 zj awd wont go into 1st even if manual shifter help plz
newfieZJ 10-29-2013 04:59 AM
Most likely a valve body issue . Partially open governor valve or sticky valve in general . Remove , clean , reassemble .
Welcome and PLEASE fill out your jeep profile !
Rob84 10-29-2013 03:22 PM
Thank you. Will give it a try. Will do on the profile.
Rob84 10-30-2013 04:58 PM
How do I find out what transmission is in my jeep?
newfieZJ 10-30-2013 06:09 PM
42re
Rob84 10-31-2013 02:34 AM
How do you know for sure?
kensnelling 10-31-2013 02:44 AM
The 42RE was the only transmission installed behind a 4.0L in '95.
Ken
Rob84 10-31-2013 04:22 AM
Cool thnx
Rob84 11-15-2013 06:44 AM
Should I replace the pressure sensor along with the shift silonoid?
xcaliber81 11-15-2013 09:57 AM
The awd is the tcase not the trans.
breeaad 11-17-2013 09:27 PM
How do you know its a shift solenoid? The PCM will put the trans into limp mode and it will not go into 1st if it detects something wrong. My GC went into limp and stayed in 2nd gear when my speed sensor went bad. Have you pulled codes?
The time now is 08:50 PM.
