(ZJ) Adding factory fog lights - how to - Page 7 - JeepForum.com
post #91 of 103 Old 08-12-2012, 09:34 PM
squazz
Originally Posted by caseyliffick View Post
This is my 95 zj. I'm assuming this is my factory plug for my fog lights.
is that near the center of the header panel?
it might be the plug for the ambient temperature sensor
these are the early model fogs that mount on top the bumper
squazz is offline
post #92 of 103 Old 08-12-2012, 09:43 PM
KoreaZJ
1994 ZJ
Fuzzy pic, but that looks like the plug to the lamp. Sure you don't already have another one tucked away on the other side?
KoreaZJ is offline
post #93 of 103 Old 08-13-2012, 01:45 PM
caseyliffick
There's definitely not another one there. I checked all around the evap canister and this is the only plug I could find. Here's a pic in the light that shows location a little better.
And here's a pic to show the plug a little better.
caseyliffick is offline
post #94 of 103 Old 08-13-2012, 02:05 PM
squazz
thats it same yellow insulator
here are pics of the factory Y harness
squazz is offline
post #95 of 103 Old 08-14-2012, 11:23 AM
caseyliffick
Awesome! That's exactly what I was looking for so I had an idea of what to pick up.
post #96 of 103 Old 08-14-2012, 03:20 PM
squazz
seems to be yet another option when it comes to the above the bumper lights was unable to get a pic of the connection on the fog end it looked like long prongs heres the jumper wire
squazz is offline
post #97 of 103 Old 08-15-2012, 07:46 PM
thathubcapguy
ok so the mystery gets bigger.
the red 96 i got my fender off of at the JY had twin plugs and they are identical to my single.
both are wrong.
the next ZJ over was a 97 limited with fogs. i took one of the connectors off the red one to try and compare.
does the harness plug into these? or do i need to take the 97 style male ends off a donor and wire it up myself?
with the cap off
97 ZJ
thathubcapguy is offline
post #98 of 103 Old 11-02-2012, 04:19 PM
BoostinChick
Originally Posted by steve L. View Post
Okay, Im stumped.
I got my fog lights a few weeks ago, and they wont plug into each other. In the first picture you have the plug on the left, thats the plug that was already in the ZJ. As you can tell they dont match up. If you look at the second picture, the plug that is already in the ZJ looks like it comes off. Does it? And if so, then how??? I can't get it off.
Any help will be greatly apreciated. I need to get my ZJ back together tonight for work in the morning. Pic's are below.
Hopefully, steve L figured this out by now, but for anyone else who might run into this I have taken pics. What is posted above are cap connectors. They should unplug like any normal ol' connector. No need to cut it, break it, etc. Here is a pic with them off -
Finally finished this install today after much procrastination. Very straight forward for my 97'. Only difference for me was the fuse box in the engine bay.
1998 Jeep Grand Cherokee 5.9L
BoostinChick is offline
post #99 of 103 Old 11-02-2012, 05:33 PM
xcaliber81
nevermind
xcaliber81 is offline
post #100 of 103 Old 12-05-2012, 05:45 PM
CMG
Do you know what brand those connectors are? I want to add aux lights using the factory plugs. Dont want to cut the harness so if I could find the type of plug I would make my aux lights plug in using the factory style connectors
CMG is offline
post #101 of 103 Old 12-05-2012, 06:14 PM
BoostinChick
They are OEM so Mopar/Jeep is the brand. I do not know the plug type. I would just add male ends on your wiring.
post #102 of 103 Old 03-08-2014, 02:15 PM
tdugger411
Thank you very much for this write up. Found 2 factory fogs at the pull apart yesterday on a 97 zj and as a bonus the bumper cover was already off. 6 bolts and 2 plugs 2 easy. I had found a switch last time I was there and thanks to this thread I knew where to install the relay I picked up for $11 at oreilly. The passenger side plug is hard to find / get to. It was above the horn on mine and unless bumper cover is off, you can't see it. From what I have seen, 96 has red plugs. 97-98 have the gray. Thanks again for posting your install and especially the pics!! Cheers
tdugger411 is offline
post #103 of 103 Old 01-20-2015, 10:33 PM
ihbinder
I'm not sure If I just go lucky or what, but all I did was change out the main light switch panel and plugged in my fog lights and they work correctly.
Now I need to find a sensor to make the auto headlight option work.
ihbinder is offline
Adding Factory Parkview rear view camera to 2007 WK jscaffidi WK Grand Cherokee & XK Commander Forum 35 05-17-2017 09:33 AM
adding fog lights ktplotts ZJ Grand Cherokee Forum 7 11-09-2009 08:33 AM
Adding fogs lights to 08, need help ecocav WK Grand Cherokee & XK Commander Forum 14 02-27-2009 02:47 AM
Adding Factory Tow wiring harness to 2wd v6 Commander rstrickl WK Grand Cherokee & XK Commander Forum 2 09-04-2007 08:15 PM
Adding Fog lights to 98 ZJ njrealtor55 ZJ Grand Cherokee Forum 1 04-13-2004 02:43 PM
