(ZJ) Adding factory fog lights - how to - Page 5 - JeepForum.com
post #61 of 103 Old 10-09-2011, 08:41 PM
nicklopic
there is 3 holes in a triangle pattern on the cross member, thats they go lol
as for the holes, any sharp blade and a lighter works well, i used a relatively dull pocket knife and heated it up with a lighter every so often, it came out really jagged, but im gonna clean it up later with a diff blade and a file
(just to the left of the sticker are the holes
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #62 of 103 Old 10-18-2011, 11:24 AM
Airborn
I dont know if i missed this, but how do you wire up the switch? Is there already wires ready for hookup? If someone could give me this answer that would be greatly appreciated.
1998 Jeep Grand Cherokee Laredo 4.0L : 172,xxx miles, IRO 3.5" F>R lift, IRO Adjustable Control Arms, IRO Adjustable Track Bars, 31" Goodyear Wrangler Authority on Cragar V5's, Pavement Pounder until I get out of college :( ...Built Not Bought #650
Spend the Time and the Money the 1st Time, You'll End Up Doing it Anyway.
Airborn is offline
post #63 of 103 Old 10-18-2011, 11:48 AM
squazz
If your jeep is wired for lights them you just swap the switch out and all is good. I would like to know how to wire a factory switch for a 93 that is not wired i wanna know how to tap in to the factory fog switch anyone got that info?
squazz is offline
post #64 of 103 Old 10-18-2011, 12:15 PM
Airborn
What if i want to just use the toggle switch that came with the fogs? How would i do that? I dont really want to buy the factory switch if i already have the toggle switch.
Airborn is offline
post #65 of 103 Old 10-18-2011, 12:36 PM
squazz
Guess you would have to trace the wire from the relay and fuse to the switch harness then tap in to it unless some one has done that work and could tell you the wire colors to cut. if your using a toggle then it would prob be easier to just use the wire harness that came with fogs and toggle switch
squazz is offline
post #66 of 103 Old 01-05-2012, 05:15 PM
kurtiscrazy
Hi I am new to this forum. I have a 1998 Grand Cherokee Laredo and I want to install fog lights. I looked under the bumper where the fog lights will be mounted and I found a plug on the driver side that looks like it is for the for lights. I can't seem to find one on the passage side. Where might the passenger side plug be? Also I called my local jeep dealer and they said according to my VIN that my car comes with the foglight harness. This is great news. I just need to cut holes in the lower bumper and mount the lights (when I looked for the harness I saw holes for the lights.
I need help finding the passenger harness and also after reading this article I dont have the relay that is in the passenger footwell. Where can I get one? When looking at the fuse box under the hood the fuse that is in the “fog light” place is a 20 and not a 30. Should I change it? Thanks so much for your help. Here is a picture of the driver side connector I found.
Also the jeep didnt come with fog light button on the left of the dash so I was going to buy a factory jeep fog light, head light switch and install it. Since I have the wiring I think I will work. I dont know though so what do you guys think? Thanks again.
This is the switch I want to buy. You can see the auto. What do I need for the auto to work. I have a "senor" on my dash but I dont know if it is a light sensor. what you think?
PLEASE HELP.
kurtiscrazy is offline
post #67 of 103 Old 01-05-2012, 08:36 PM
squazz
i have a set of factory fogs and that switch forsale pm me if you want them
the plugs are behind the horn and behind the evap canister
squazz is offline
post #68 of 103 Old 01-06-2012, 10:48 AM
ZJJAMES
I have the factory lights and hooked the wireing up to a set of HID fogs. I hooked one up and tested it and it worked fine then when I hooked the second one up they no longer worked. I dont understand why that would blow the fuses or relay.
96 ZJ V8, Hybrid cage, HP44, Ultimate 8.8, 242tc swap, Tom woods shafts, long arms, 35s...
ZJJAMES is offline
post #69 of 103 Old 02-27-2012, 11:39 AM
TontoKowalski
does anybody know where I can purchase both a replacement light switch with fog light and a relay?
i'm thinking they both would be like $30, no?
TontoKowalski is offline
post #70 of 103 Old 02-27-2012, 12:59 PM
jmonty0523
Best spot for a switch would be a junkyard. Brand new switch is probably gonna be just over $100. Relay, parts store, under $10. I paid $20 for my junkyard switch, probably could get a cheap one off eBay if something similar if u look enough.
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #71 of 103 Old 02-27-2012, 01:00 PM
squazz
pm'ed
squazz is offline
post #72 of 103 Old 03-13-2012, 09:05 AM
1Aauto
Vendor
1Aauto's Avatar
I was thinking of adding the fogs to my 97 Grand and stumbled onto this thread. Pretty cool write up. If some of you guys would rather buy new switches and OE type fogs we sell them on the site. I'll post some links up for you guys.
1997 - 1998 Jeep Grand Cherokee Fog Driving Light Pair
1996 Jeep Grand Cherokee Fog Light Pair
1993 - 1995 Jeep Grand Cherokee Fog Driving Light Pair
Jeep Grand Cherokee Headlight Switch
SHOP HERE FOR AWESOME
1Aauto is offline
post #73 of 103 Old 04-04-2012, 08:54 AM
ExpeditionXJ
Anyone have a part number for the relay that gets installed into the pass side footwell panel?
I have everything else done, just need to install relay and test.
Disregard, found one in garage that matches the number on relay above this one.
ExpeditionXJ is offline
post #74 of 103 Old 04-04-2012, 09:23 AM
thrashin
My ZJ came with the factory fogs but one got ripped off by a minivan along with my bumper cover. Can I use the stock switch and wiring/connector and use aftermarket off road style light instead without mods to relay or fuses etc?
thrashin is offline
post #75 of 103 Old 04-29-2012, 06:23 PM
341012
you can use the same output wires, as long as the wiring is still there
341012 is offline
Adding Factory Parkview rear view camera to 2007 WK jscaffidi WK Grand Cherokee & XK Commander Forum 35 05-17-2017 09:33 AM
adding fog lights ktplotts ZJ Grand Cherokee Forum 7 11-09-2009 08:33 AM
Adding fogs lights to 08, need help ecocav WK Grand Cherokee & XK Commander Forum 14 02-27-2009 02:47 AM
Adding Factory Tow wiring harness to 2wd v6 Commander rstrickl WK Grand Cherokee & XK Commander Forum 2 09-04-2007 08:15 PM
Adding Fog lights to 98 ZJ njrealtor55 ZJ Grand Cherokee Forum 1 04-13-2004 02:43 PM
