(ZJ) Adding factory fog lights - how to - Page 4 - JeepForum.com
post #46 of 103 Old 06-29-2011, 10:41 PM
zander21510
Yea I checked by the horns, under both sides....couldn't find a plug. Will check the relay plug tomorrow...its the one thing I forgot at the junk yard (well I also forgot my toolbox :...thats why I have to go back) so I will look at that tomorrow...and maybe try and pull the wiring from an old jeep.
zander21510 is offline
post #47 of 103 Old 06-29-2011, 10:46 PM
squazz
Let me know how pulling that harness goes I thought about it but it seems a pita did you already get a headlight switch with the fog option if not I got an extra
squazz is offline
post #48 of 103 Old 06-29-2011, 10:51 PM
zander21510
Yea I got and installed the switch...I'll try and take the wiring out unless its terribly complicated....I also couldn't find the plug for the auto headlight sensor...that wiring looks too deeply integrated for me to pull...I want those blasted foglights! lol
post #49 of 103 Old 06-29-2011, 10:54 PM
zander21510
Oh and I already pulled foglights from the junkyard...I'm so close! I thought the wiring was included on all jeeps
post #50 of 103 Old 06-30-2011, 09:07 AM
blackzj
how hard was it to pull the panel dimmer out? what auto headlight sensor?
blackzj is offline
post #51 of 103 Old 06-30-2011, 10:18 AM
zander21510
not that hard to pull (a lot of stuff already broken off/taken apart), hella hassle to install. I think part of the sterring wheel is supposed to come off to get that bezel out...may be diffrent on a 96 but I nearly cracked the thing in half trying to get it out :P. The auto headlight sensor that is in the dash that some ZJ's came with, most switches with fog lights have an option for auto headlights, but you need the sensor
post #52 of 103 Old 06-30-2011, 11:52 AM
squazz
The plug.for the autosensor is under the dash pad close to where the tweeterspeaker plugs are on driver side the sensor is a blue disk that hooks to the defroster vent grill
squazz is offline
post #53 of 103 Old 06-30-2011, 12:14 PM
zander21510
Well after searching for maybe the 10th time today, I came to the conclusion that my Laredo is one of the few that never came with the fog light plug or the auto headlight sensor plug. Like you said the relay plug didn't have any metal contacts in it, and I gave up on the auto headlight sensor a while back. So basically I wasted a bunch of time and a little money installing that auto headlight/fog light switch..and I'm not going to take it out anytime soon considering the horrible time I had taking it out/installing it in the first place...live and learn I suppose.
post #54 of 103 Old 06-30-2011, 12:28 PM
speedbucket
toggle switch is your friend
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #55 of 103 Old 06-30-2011, 01:53 PM
zander21510
ha if I do end up putting fog lights on it, they won't be factory and I will install a toggle switch
post #56 of 103 Old 06-30-2011, 02:08 PM
airwolf9090
If he don't need it i sure could use it in my Orvis! My dimmer has been messed up from day one and now its gotten so tweaked it switches the fog lights on and off by it's self and if i have it on auto when it starts messing up my headlights go off and on.... Damn slider contacts.
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #57 of 103 Old 10-07-2011, 12:43 AM
brettm28
96 zj
Hi, im new to this whole jeepforum.com thing, but i have a 96 ZJ and it did not come with fog light and i want to add them on what all do i need to buy, besides the lights and bulbs and switch? when i have the switch were to i put it because my jeep dd not come that option so i dont see a place where i install the fog light switch? PLZ help me out!
brettm28 is offline
post #58 of 103 Old 10-07-2011, 06:46 AM
squazz
Welcom to the forum and thanks for using the search function. The switch will be a replacement for what is now the headlight switch to the left of the dash and your being a 96 everything else is on page one of this thread
squazz is offline
post #59 of 103 Old 10-07-2011, 09:54 AM
canadiandiesel
1994 ZJ
I wonder if people actually talk like this in public and yes I agree the search function is well used in this persons case
Sent from my iPhone using technology
canadiandiesel is offline
post #60 of 103 Old 10-09-2011, 08:11 PM
brettm28
When installing my fog lights whatshould i bolt the brackets on to?? The frame? or what so what should i use to cut the vents out of my bumper?
brettm28 is offline
Adding Factory Parkview rear view camera to 2007 WK jscaffidi WK Grand Cherokee & XK Commander Forum 35 05-17-2017 09:33 AM
adding fog lights ktplotts ZJ Grand Cherokee Forum 7 11-09-2009 08:33 AM
Adding fogs lights to 08, need help ecocav WK Grand Cherokee & XK Commander Forum 14 02-27-2009 02:47 AM
Adding Factory Tow wiring harness to 2wd v6 Commander rstrickl WK Grand Cherokee & XK Commander Forum 2 09-04-2007 08:15 PM
Adding Fog lights to 98 ZJ njrealtor55 ZJ Grand Cherokee Forum 1 04-13-2004 02:43 PM
