(ZJ) Adding factory fog lights - how to - Page 3 - JeepForum.com
post #31 of 103 Old 06-27-2011, 11:14 PM
zander21510
ha I wish i could find some intact lamps...the ones on my favorite little Orvis, the lenses are completely missing and the bulbs are smashed
zander21510 is offline
post #32 of 103 Old 06-27-2011, 11:18 PM
blackzj
jy should have them are you going to stay with the stock bulb?
blackzj is offline
post #33 of 103 Old 06-27-2011, 11:19 PM
zander21510
yea probably. I'll look around...can you use the fogs in a 96+ that are in the bumper?
post #34 of 103 Old 06-27-2011, 11:21 PM
blackzj
ummm idk i think so i think almost all the parts are the same
blackzj is offline
post #35 of 103 Old 06-27-2011, 11:23 PM
zander21510
cuz this JY has a lot of 96+...i'll have to look! i may be able to put this together earlier than I thought lol
post #36 of 103 Old 06-27-2011, 11:26 PM
blackzj
if not you can sell them on here and make money never no
blackzj is offline
post #37 of 103 Old 06-29-2011, 05:51 PM
zander21510
I know I posted a seperate thread about this, but those following this might be able to help, I cannot find the wire on the passenger side to plug the fog light harness into...I looked everywhere, does anyone have pictures of where on earth it is? I have a 95 ZJ Laredo.
post #38 of 103 Old 06-29-2011, 07:44 PM
squazz
Should be to the bottom left of the rad/condensor behind the grill took me a while to find it to
My 93 was not wired but my 94 was wired with the passanger side but not the driver side
squazz is offline
post #39 of 103 Old 06-29-2011, 07:48 PM
zander21510
The very bottom of the radiator? Or bottom left of the grill?
post #40 of 103 Old 06-29-2011, 07:52 PM
squazz
Let me get out of bed find a flashlight ill go get a pic
squazz is offline
post #41 of 103 Old 06-29-2011, 07:55 PM
zander21510
Thanks I really appreciate it
post #42 of 103 Old 06-29-2011, 08:14 PM
squazz
Could not find a ****in flashlight pissed me off
but it is behind grill in front of rad maybe covered by the black rubber splash guard real short not much play in the wire
others have bun found under where the horn mounts extra plug under there
It's.down between there some where
squazz is offline
post #43 of 103 Old 06-29-2011, 08:17 PM
zander21510
alright well I'll go look, thanks for the help!
post #44 of 103 Old 06-29-2011, 08:24 PM
zander21510
Ok, well all I found was that harness of wires, covered in black tape....I don't think its big enough to have an entire plug in it....and I looked all up and down it this afternoon...do you think I may just not have it?
post #45 of 103 Old 06-29-2011, 10:23 PM
squazz
Dont think it is in that
Did you check the distrubtion box where the.fog relay goes if the slot wil not accept the fuse kike there is play in it and no metal conectors then it's not wired did you look under passanger side by horn?
squazz is offline
Adding Factory Parkview rear view camera to 2007 WK jscaffidi WK Grand Cherokee & XK Commander Forum 35 05-17-2017 09:33 AM
adding fog lights ktplotts ZJ Grand Cherokee Forum 7 11-09-2009 08:33 AM
Adding fogs lights to 08, need help ecocav WK Grand Cherokee & XK Commander Forum 14 02-27-2009 02:47 AM
Adding Factory Tow wiring harness to 2wd v6 Commander rstrickl WK Grand Cherokee & XK Commander Forum 2 09-04-2007 08:15 PM
Adding Fog lights to 98 ZJ njrealtor55 ZJ Grand Cherokee Forum 1 04-13-2004 02:43 PM
