ZJ 8.8 swap > need help - Page 2 - JeepForum.com
post #16 of 22 Old 05-26-2010, 08:25 AM Thread Starter
rustynail
Originally Posted by CatSplat View Post
Dang, too bad you're out in Van, I've been looking for a LSD 44A to replace my turd35.
If you find one without LS you can easily pop in an Aussie locker. If I didn't have LS I would likely just truss and lock my 44A.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #17 of 22 Old 05-27-2010, 05:21 PM Thread Starter
rustynail
If I stay at 3:73 for now and put in a locker that includes the carrier like an Eaton e-locker or ARB, will I have to set up the gears with a gear install kit?
- Russ
post #18 of 22 Old 05-27-2010, 07:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
yes. You'll need to check the pattern at a minimum.
ratmonkey is offline
post #19 of 22 Old 05-27-2010, 09:46 PM
ZJJAMES
Get gears at the same time why pay to have the stock ones set up. I went with 4.88s and love them.
96 ZJ V8, Hybrid cage, HP44, Ultimate 8.8, 242tc swap, Tom woods shafts, long arms, 35s...
ZJJAMES is offline
post #20 of 22 Old 04-17-2013, 08:03 PM
KyleWHunter
Hey in the 8th picture down 1st pagewhat is that little nipple looking piece I noticed you kept it on, yet I've seen other pics where it was grinded off, hope it wasn't important
KyleWHunter is offline
post #21 of 22 Old 04-17-2013, 09:31 PM
ZJJAMES
I did not grind it off, it's still there. That is the breather for the axle. Lets pressure out, there is one on the stock axles as well.
ZJJAMES is offline
post #22 of 22 Old 08-13-2015, 10:54 PM
Bgreenwood94
I'm going to attempt an 8.8 swap. How do you know where to mount the all the brackets on the 8.8?
Bgreenwood94 is offline
doing 247/242 swap....need advice on front output shaft swap.. krazyteggy ZJ Grand Cherokee Forum 5 12-30-2009 06:44 PM
To swap in a 44A or not? chadgtr ZJ Grand Cherokee Forum 12 03-13-2009 02:28 AM
91 -97 Tcase Swap or motor swap ezrider327 ZJ Grand Cherokee Forum 6 05-12-2008 11:47 AM
D30 swap from ZJ to WJ MuddyV8YJ ZJ Grand Cherokee Forum 21 01-05-2007 06:20 PM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
