ZJ 6cyl runs bad after 15 minutes of driving? - JeepForum.com
post #1 of 5 Old 08-02-2009, 02:19 AM Thread Starter
jeepspotter
After chasing a bunch of little problems with my 95 ZJ 4.0 6 cyl that I just bought, the last engine issue eludes me....
The engine runs strong and clean when my jeep has been sitting for a while...until I drive it for 10-15 minutes, out of nowhere, starts to sputter and studder like mad. It is still driveable at this point, but runs horribly and makes awful noises (perhaps misfiring or bad fuel)
If I let it sit for a couple hours to cool back down, it will run perfect for another 10-15 minutes till it warms back up again. Im stuck, any suggestions on this?
No throwing any codes AFAIK, and I haven't been able to find anything like this searching the forums. Any related posts?
jeepspotter is offline
post #2 of 5 Old 08-02-2009, 02:25 AM
kwellzz
how many miles?
Seems like it is related to the engine going into closed mode once warm. Have you searched for 02 sensor symptoms?
Denver Motorcycle Repair
kwellzz is offline
post #3 of 5 Old 08-02-2009, 02:44 AM Thread Starter
jeepspotter
155xxx miles.
Why symptoms should I look for in a bad O2 sensor?
post #4 of 5 Old 08-02-2009, 04:17 AM
sidescrollin
1950 M-38
You aren't really giving alot of information.
So after a while it starts misfiring and wanting to quit??? after you have driven it a while...could be a number of things. what it reminds me of is the fuel pump on a disco I had. So it could be your solenoid overheating and then not feeding enough gas to the car.
It could be a bad o2 sensor and is making different reading and causes you to run rich or lean and stutter.
Is your MAF clean?
sidescrollin is offline
post #5 of 5 Old 08-02-2009, 02:45 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
disconnect the upstream o2 sensor and drive it around for a while. it will throw a code but if it doesn't do any of the symptoms you're experiencing you've found your bad part.
ratmonkey is offline
30 minutes and more cargo room in the WJ theksmith WJ Grand Cherokee Forum 121 11-25-2014 06:38 PM
Dies after 15-20 minutes daveyboy43 ZJ Grand Cherokee Forum 14 04-01-2008 06:43 PM
A/C Works for only 15 minutes chris7874 WJ Grand Cherokee Forum 7 08-07-2007 09:55 AM
Help a TJ owner out for a few minutes :) Rubi22 ZJ Grand Cherokee Forum 4 05-11-2007 05:29 AM
HELP Fast - Need Answer in next few minutes poconosms1 ZJ Grand Cherokee Forum 10 02-28-2005 09:20 AM
