ZJ 5spd Swap - Page 9 - JeepForum.com
post #121 of 124 Old 05-23-2013, 03:31 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by dunkeye11 View Post
No no I don't mean that I mean once you are done. the shifter fits in the same place like an AX-15 would because I saw someone who used another trans and they had to hack up there center console
you'll have to hack up the trans tunnel/console with the ram unit, the dakota unit is closer but will still require cutting.
ratmonkey is offline
post #122 of 124 Old 12-15-2013, 10:08 PM
MurdaJs
Just about finished with the swap. A few things i learned:
Dakota 231d hd has a larger output, meaning our stock driveshaft wont work. Also, there is no speedo gear like in a jeep tcase. Two fixes i came up with: frankenstine dakota/jeep driveshaft, or jeep slip yoke eliminator and new ds. The sye route will also fix the speedo problem.
I ended up swapping in a 242j from a 4.0 zj. Input shafts were both .840. Going from 249 internal slip yoke to 242 external slip yoke allowed the stock driveshaft to stay unmodified. While the nv3500 is shorter than the 44re, 242 external is longer than the 249 internal. Overall my driveline is about an inch shorter now.
I was havin trouble finding a dakota or ram pcm so i ended up going the SCT route. FlyinRyan tuned mine and in addition to flashing my pcm for performance, he was able to delete the auto trans functions from my pcm. This translates to NO CELS while using your stock zj pcm. Now an SCT tuner and custom tuning does cost much more than a dakota or ram pcm, but you also get better performance and dont have to hunt down a possibly unusable pcm.
MurdaJs is offline
post #123 of 124 Old 12-18-2013, 06:19 PM
MurdaJs
Finally finished and driving, couldnt have done it without your help rat
MurdaJs is offline
post #124 of 124 Old 12-18-2013, 07:56 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Very nice.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline
5spd in my zj ljworkman ZJ Grand Cherokee Forum 4 06-06-2011 08:35 AM
help out with a 5spd zj zippome Grand Cherokee General Discussion 5 04-18-2009 08:05 PM
found a 5spd zj in the JY jersey_jim ZJ Grand Cherokee Forum 5 10-20-2007 10:26 AM
The V8 5spd ZJ question Aceladriver ZJ Grand Cherokee Forum 15 06-14-2007 04:04 PM
5spd GC imnotu ZJ Grand Cherokee Forum 2 12-09-2003 02:55 PM
