ZJ 5spd Swap - Page 8 - JeepForum.com
post #106 of 124 Old 04-26-2013, 06:47 PM
MurdaJs
What ecm are the other successful swaps running? Obdii
MurdaJs is offline
post #107 of 124 Old 04-26-2013, 07:05 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
ram or dak.
i'm on a 99 ram. i've seen 97-99 ram and dak units in the few that work.
ratmonkey is offline
post #108 of 124 Old 04-29-2013, 02:13 PM
MurdaJs
Thanks, buying a ram unit today hopefully.
Picked my trans up on sat, came with the 231d hd, its isl, is it worth using? I noticed it doesnt have the speedo on the tail shaft, will a sye fix that? Or should i just pick up a jeep tcase? The 249 im replacing is also isl, the tail shaft swappable maybe?
MurdaJs is offline
post #109 of 124 Old 05-01-2013, 02:39 AM
moparrr07
i drove around on the stock pcm just fine for about 2 weeks before i got my manual one in, it works and drive ok, but like he said, on decel and flares on shifts its funny, plus CEL is on, i got a 98 dakota unit, make sure the one you buy has cruise control otherwise yours wont work, also the other huge difference is the a/c, dakotas and zj have flipped triggers for the a/c command on, because the zj has a bcm and dakota doesnt, one needs a ground and one needs a power, a simple relay wired up to flip it will work fine
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #110 of 124 Old 05-01-2013, 02:05 PM
MurdaJs
Cool thanks for the info.
I went ahead and ordered a new flywheel, same price with shipping as my local yards charge. I need the bolts from the dealer, what about a shim or ring gear? Rockauto has a .25 an .5 inch shim listed
MurdaJs is offline
post #111 of 124 Old 05-01-2013, 03:59 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
ring gear is part of the flywheel, never seen shims on any part of the clutch or flywheel.
post #112 of 124 Old 05-19-2013, 12:56 PM
MurdaJs
Thanks, i think the shims might be available in case you turn your used flywheel and then need to compensate.
Just a lil somethIn i noticed yesterday, my auto tranny, od and 249 measures 3 ft 8.5 inches in total length, exactly the same as my soon to be installed dakota nv3500 which came with a 231hd. I might dodge needing new driveshafts
MurdaJs is offline
post #113 of 124 Old 05-19-2013, 01:36 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
the rear output on the 231d is longer, rear will probably fit, front most likely will be short.
the dakota nv3500 is about 3" shorter than the 44re.
post #114 of 124 Old 05-23-2013, 01:50 AM
MurdaJs
[*] the correct pilot bearing for magnum motors is national bearing 1969-07061457[/LIST]
[CENTER]Seen here
Whered ya get that? I can only find it at one site, and the site has a bad rep. Will this one work?
MurdaJs is offline
post #115 of 124 Old 05-23-2013, 06:47 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
All the local stores had it, rock auto had it, summit had it.
post #116 of 124 Old 05-23-2013, 08:28 AM
dunkeye11
Is the NV3500 strong enough for the 5.2? I assume is?
dunkeye11 is offline
post #117 of 124 Old 05-23-2013, 10:39 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Considering that's what it was built for.
post #118 of 124 Old 05-23-2013, 01:46 PM
dunkeye11
So it fits well in the ZJ?
post #119 of 124 Old 05-23-2013, 02:38 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
takes a ton of work as outlined in the initial post.
post #120 of 124 Old 05-23-2013, 02:55 PM
dunkeye11
No no I don't mean that I mean once you are done. the shifter fits in the same place like an AX-15 would because I saw someone who used another trans and they had to hack up there center console
5spd in my zj ljworkman ZJ Grand Cherokee Forum 4 06-06-2011 08:35 AM
help out with a 5spd zj zippome Grand Cherokee General Discussion 5 04-18-2009 08:05 PM
found a 5spd zj in the JY jersey_jim ZJ Grand Cherokee Forum 5 10-20-2007 10:26 AM
The V8 5spd ZJ question Aceladriver ZJ Grand Cherokee Forum 15 06-14-2007 04:04 PM
5spd GC imnotu ZJ Grand Cherokee Forum 2 12-09-2003 02:55 PM
