ZJ 5spd Swap - Page 6 - JeepForum.com
post #76 of 124 Old 08-14-2012, 08:34 PM
General_Jeep
1994 ZJ
I have a Dodge ram 1500 5.2L V8 4x4 and it already has 145K miles on it. I use it as a plow truck so it gets bashed hard, I also don't drive it nicely. I've gone through 2 clutches(one was my mothers fault...) But the NV3500 is still running good.
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #77 of 124 Old 08-15-2012, 10:13 AM
moparrr07
theres a guy on dakota durango forum that didnt blow his up until he he 500 lbft of torque, everyone on there agreed with him, most people find that to be the limit
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #78 of 124 Old 08-15-2012, 03:31 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Same forum i see them regularly blow then up with stock 360 swaps.
ratmonkey is offline
post #79 of 124 Old 08-15-2012, 07:49 PM
moparrr07
this guy says there are different strength nv35xx trans'
http://www.dakota-durango.com/forum/...04&postcount=5
hes just a few who have had good luck with the 3500
http://www.dakota-durango.com/forum/...46&postcount=9
http://www.dakota-durango.com/forum/...4&postcount=18
http://www.dakota-durango.com/forum/...4&postcount=21
anyone can kill any trans if they dont know how to treat it, id say 90% of the people that say they can drive a manual and do every day, do it incorrectly, and using the engine to brake without double clutching with burn through the syncos quicker than anything
im sorry you had problems with yours rat, didnt you say you had pilot bearing problems? if that pilot bearing isnt perfect the imput bearing wont last to long
post #80 of 124 Old 08-16-2012, 07:12 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
The pilot was trashed, but the input bearing was fine web i went through all the parts from the failed trans.
The synchros were in good shape too.
Stripped the input gear and counter shaft, which is a common failure.
post #81 of 124 Old 11-11-2012, 12:27 PM
Mark-318-IT
hi looking on the web trying to find a 5 spd for the zj i found thr ax 15 "terminator"
waht do you think about?
for street use? i mean some launches...
Mark-318-IT is offline
post #82 of 124 Old 11-11-2012, 12:35 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
Its in v8 Toyota pickups it's a good transmission. But still truck ratios, not something friendly to drag racing. It'll hold up though.
post #83 of 124 Old 11-11-2012, 01:53 PM
Mark-318-IT
understood thanks, i think that maybe this can be the chioice...
post #84 of 124 Old 03-27-2013, 05:37 PM
MurdaJs
Any idea on what donor vehicles have the desirable flexplate?
MurdaJs is offline
post #85 of 124 Old 03-27-2013, 08:45 PM
moparrr07
a flexplate is for an automatic, flywheels are for manuals,
if you have a 5.2, get a flywheel from a manual trans dakota or ram with a 5.2
if you have a 5.9, get a flywheel from a manual trans ram with a 5.9
the 5.2 and 5.9 have different ballence methods requiring weights on the flywheel or not, so you must get one for the matching engine
post #86 of 124 Old 03-27-2013, 09:03 PM
comptiger5000
Termi AX-15 with 3.08s in the axles would be ok for street gearing and would cruise about 100 rpm lower at 60 than a stock 44/46RE / 3.73 combo. It's my plan for when my 46RE eventually gets tired of life.
comptiger5000 is offline
post #87 of 124 Old 03-27-2013, 09:19 PM
MurdaJs
Lol, im learning as i go!
Thanks
MurdaJs is offline
post #88 of 124 Old 03-28-2013, 11:24 AM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
The motor doesn't like running that low. It will lug and you'll get worse economy.
post #89 of 124 Old 03-28-2013, 11:43 AM
comptiger5000
Hmm... It would put the revs the same as a stock 5 speed 4.0, about 1660 at 60 mph. I currently turn 1750 and it pulls up 9% grades in OD just fine, which tells me it's probably a bit over-geared for the motor, especially considering that making an identical highway run, at the same speed on the same day in a 4.0 WJ with 3.73s and the same size tires, yields 4 - 5 mpg better than I get.
I picked up a solid 1 mpg on the highway after the cam (and pulls harder at 1100 rpm than it did stock). It's happy being lugged down to 850 rpm with the manual lockup switch, although it's not very efficient below 1200 or so, as I get better mpg at 45 than at 40.
Considering how tall GM gears some of their cars (Vettes in particular), where some of them are turning between 1500 - 1600 rpm at 70 mph, I don't think turning 1660 at 60 mph (1940 at 70 mph) is tall enough to lug the motor. Currently, I spin 2050 at 70 mph.
post #90 of 124 Old 03-28-2013, 01:16 PM Thread Starter
ratmonkey
R.I.P.
ratmonkey's Avatar
don't compare to a gm or other style vehicle, completely different motor and completely different aerodynamics dictating different power level needs at different speeds.
at 60 these motors do best above 2000rpm. both the v8 and the i6. they're really undergeared from the factory and hate being lugged down.
5spd in my zj ljworkman ZJ Grand Cherokee Forum 4 06-06-2011 07:35 AM
help out with a 5spd zj zippome Grand Cherokee General Discussion 5 04-18-2009 07:05 PM
found a 5spd zj in the JY jersey_jim ZJ Grand Cherokee Forum 5 10-20-2007 09:26 AM
The V8 5spd ZJ question Aceladriver ZJ Grand Cherokee Forum 15 06-14-2007 03:04 PM
5spd GC imnotu ZJ Grand Cherokee Forum 2 12-09-2003 01:55 PM
